[mapserver-dev] Re: problem with WFS DWithin
Paul Ramsey pramsey at cleverelephant.ca
Thu Mar 27 16:04:10 EDT 2008
SQL/MM is not helpful, there's no DWithin in the draft I have
available. All I have left is to appeal to Oracle's
SDO.WITHIN_DISTANCE and note that it also shares the GeoAPI
definition: http://download.oracle.com/docs/html/A85337_01/sdo_objg.htm#854615
Whether WITHIN_DISTANCE is semantically equivalent to DWITHIN is left
as an exercise for the pub after work.
P.
On Thu, Mar 27, 2008 at 11:23 AM, Yewondwossen Assefa
<yassefa at dmsolutions.ca> wrote:
> Paul Ramsey wrote:
>  > Assefa,
>  > I can't see DWithin in SFSQL.
>   You are right. Within is defined in SFSQL. I meant that I interpreted
>  DWithin using the same definition as Within.
>  > In OGC Filter, the "definition" is useless!  "The spatial operators
>  > DWithin and Beyond test whether the value of a geometric property is
>  > within or beyond a specified distance of the specified literal
>  > geometric value."
>   True :)
>  > The Javadoc from GeoAPI is clear and fits my personal understanding:
>  > http://geoapi.sourceforge.net/2.0/javadoc/org/opengis/filter/spatial/DWithin.html
>  > There is surprisingly little clarity in the stuff I netted from
>  > Google. When I get home to my SQL/MM file I'll see if ISO is clearer.
>  If there is some clear definition/consensus on this, I see no problem
>  changing it to fit the GeoAPI way, although I think Within and DWithin
>  should behave similarly.
>  Best Regards,
>  > Paul
>  > On Thu, Mar 27, 2008 at 9:07 AM, Yewondwossen Assefa
>  >> Hi There,
>  >>  It is implemented using geos within functionality where the query shape
>  >>  is a buffered copy of the original shape.  Same for within.
>  >>  My interpretation of the within/dwithin  operator looking at the specs
>  >>  "simple feature specification for sql" was that the feature should be
>  >>  totally contained. If that is not the case, It can easily be changes to
>  >>  use the distance geos operator.
>  >>  Best Regards
>  >>  Paul Ramsey wrote:
>  >>  > DWIthin(A, B, D)
>  >>  > should be functionally identical to
>  >>  > Distance(A, B) < D
>  >>  > so no, what you describe doesn't sound like a correct DWithin, Bart.
>  >>  > BTW, if it's implemented as
>  >>  > Intersects(A, Buffer(B, D))
>  >>  > it's incredibly inefficient.
>  >>  > P.
>  >>  > On Thu, Mar 27, 2008 at 8:19 AM, Bart van den Eijnden (OSGIS)
>  >>  > <bartvde at osgis.nl> wrote:
>  >>  >> Okay, it seems it only returns features if they are totally contained within
>  >>  >>  the searchshape + distance (the buffered linestring).
>  >>  >>  Is this the way DWithin is supposed to behave? I am not a geometry operator
>  >>  >>  specialist unfortunately, but my expectation was to get any of the polygons
>  >>  >>  containing the buffered linestring.
>  >>  >>  A small buffer (500 m) selects nothing:
>  >>  >>  http://www.osgis.nl/download/umn/dwithin1.png
>  >>  >>  A bigger buffer (2500 m) only selects 3 polygons:
>  >>  >>  http://www.osgis.nl/download/umn/dwithin2.png
>  >>  >>  Best regards,
>  >>  >>  Bart
>  >>  >>  OSGIS, Open Source GIS
>  >>  >>  http://www.osgis.nl
>  >>  >>  --------- Oorspronkelijk bericht --------
>  >>  >>  Van: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
>  >>  >>  Naar: mapserver-dev at lists.osgeo.org <mapserver-dev at lists.osgeo.org>
>  >>  >>  Onderwerp: problem with WFS DWithin
>  >>  >>  Datum: 27/03/08 14:59
>  >>  >>  > Hi list,
>  >>  >>  > I can't get a DWithin filter containing a LineString to work. I am using a
>  >>  >>  > polygon layer. It doesn't select anything. Using 5.0.2.
>  >>  >>  > A DWithin containing a Polygon works fine.
>  >>  >>  > Any ideas what could be causing this?
>  >>  >>  > Did anybody else experience the same thing?
>  >>  >>  > Best regards,
>  >>  >>  > Bart
>  >>  >>  > http://www.osgis.nl
>  >>  >>  _______________________________________________
>  >>  >>  mapserver-dev mailing list
>  >>  >>  http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>  >>  Assefa Yewondwossen
>  >>  Software Analyst
>  >>  Email: assefa at dmsolutions.ca
>  >>  http://www.dmsolutions.ca/
>  >>  Phone: (613) 565-5056 (ext 14)
>  >>  Fax:   (613) 565-0925
>  Assefa Yewondwossen
>  Software Analyst
>  Fax:   (613) 565-0925
