[mapserver-dev] Wrong number of query results (php mapscript)between a static and dynamic setup
Steve Lime Steve.Lime at dnr.state.mn.us
Wed May 7 01:42:45 EDT 2008
Will take a look...
Steve
>>> Nicol Hermann <mapserver at geoworld.de> 05/06/08 11:58 PM >>>
Hi Developers,
i posted this issue already in the mapserser.user list but get no
response.
So i will try my luck on the developer list.
Can anybody reproduce/confirm the reported behaviour on his machine?
Anything i am doing wrong?
Here is my problem:
i am fighting with a real strange behaviour of mapserver/php mapscript.
This concerns the result of an attribut query.
I get different results using a completely dynamic setup and static
mapfile.
I prepared a couple of scripts to reproduce the issue ('ms.zip').
k.map  = a mapfile
k1.php = php mapscript with a completely dynamic setup (include of
kq.php)
k2.php = php mapscript which reads the setup from 'k.map' (include of
kq.php)
kq.php = attribut.query
tmp_klima.shp|dbf|shx= Sample Shape File with some records
As both scripts (k1.php and k2.php) uses the same data source and the
same querys/expressions i expect the same results.
In fact the query result of both scripts differs although they use the
same attribut query (kq.php).
k1.php = returns the correct results
k2.php = returns a wrong number of query results (2, STATION=Wilkes is
missing)
I run both scripts with mapserver 5.0.2 on a debian lenny system.
I have no idea what happens here.
Can the behaviour have something to do with the minus values in the
queried attribut field (TJ)?
Thanks for any hint!
Nicol
