[mapserver-dev] More Performance
Paul Ramsey
pramsey at cleverelephant.ca
Mon May 12 15:44:06 EDT 2008
Sadly, no, I don't have AGG working under OS/X 10.5 yet.
http://trac.osgeo.org/mapserver/ticket/2368
I can't even get a compile on my Linux Centos image... agg has been a
real PITA to get compiled.
P.
On Mon, May 12, 2008 at 12:32 PM, thomas bonfort
<thomas.bonfort at gmail.com> wrote:
> From the graph it seems like gd's font rendering/cache is a good
> culprit. Paul, is it easy for you to try the same thing with the agg
> backend (with an up-to-date trunk as I just removed the gd font calls
> from the agg code). from my tests agg was substantially faster than gd
> at font rendering.
> thomas
> On Mon, May 12, 2008 at 9:24 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
>> This sounds like a great opportunity to collaborate. We all want to go fast and each project
>> would push the other. Andrea mentioned in Victoria that they would make their test framework
>> available but I've never been able to find it on their site. Might Andrea be interested in that?
>> As for labeling. Does the label cache processing have an impact? Could try BITMAP vs TTF fonts
>> and TTF with and without the labelcache.
>> Steve
>> >>> On 5/12/2008 at 2:17 PM, in message
>> <30fe546d0805121217n33217949ue308e0dbe42aa40d at mail.gmail.com>, "Paul Ramsey"
>> <pramsey at cleverelephant.ca> wrote:
>> > I don't have an environment, I'm just taking the info from Andrea. The
>> > effect of loading a font is definitely noticeable... my
>> > small-map-on-large-file (no labels) case draws faster than the simple
>> > draw-50-states (state name labels) case, and the difference is the
>> > font loading. The curl init overhead is there too, though I see now
>> > drilling lower into it that it is specific to curl-with-ssl,
>> > initializing the SSL. Regardless, something that is removable for a
>> > few ms gain.
>> > No details on the use cases, I'm afraid. Andrea sent me his test map,
>> > but it's really just a simple shapes with colors and labels, no
>> > selectivity case. He is trying to build a performance testing
>> > framework that he can use to regress geoserver over time, to ensure
>> > new development doesn't destroy performance. It's all HTTP based, so
>> > we could use the same infrastructure.
>> > P.
>> > On Mon, May 12, 2008 at 12:07 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
>> > wrote:
>> >> Do you have a GeoServer/MapServer test environment setup? I'd really like to
>> > get one
>> >> in place. It's impossible to know how fast or slow MapServer is with out it.
>> > I'm assuming
>> >> Andrea has one since he's still testing head-to-head.
>> >> Are the various use cases detailed some place?
>> >> Steve
>> >> Thanks for the Shark tip, hadn't heard of that one.
>> >>>>> On 5/12/2008 at 1:50 PM, in message
>> >> <30fe546d0805121150t765a77bl80ecc5ab3092070d at mail.gmail.com>, "Paul Ramsey"
>> >>> Andrea Aime pointed out that Geoserver is still running about 3-times
>> >>> as fast as Mapserver in some use cases, which has prompted me to
>> >>> discover Shark (note to developers on OS/X, learn to run Shark).
>> >>> Among the things Shark tells me is that the epsg configuration file
>> >>> remains the biggest (avoidable, but non-obvious) performance issue,
>> >>> potentially hogging huge amounts of resources, since the projections
>> >>> are loaded even for layers that aren't being rendered. Even worse,
>> >>> it's a performance issue that fcgi doesn't fix, since the loading
>> >>> happens in msLoadMap.
>> >>> Another thing Shark tells me is that we are burning resources in
>> >>> curl_global_init (called from msHTTPInit via msHTTPInitRequestObj)
>> >>> even when there are no WMS or WFS layers defined. This is eating
>> >>> about 5% of the total cycles, on a fairly well-tuned map file, and
>> >>> could be fixed.
>> >>> Finally, the biggest single resource muncher in this small-easy-map
>> >>> case is loading the font file. This could be an artefact of the OS/X
>> >>> font loading, or it could be generic. It looks like gd has a font
>> >>> cache, so perhaps this goes away in FCGI. I guess that should be my
>> >>> next test, because if it doesn't go away it's a big win in the FCGI
>> >>> case to make it go away.
>> >>> P.
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
