[mapserver-dev] New demo proposal...
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu May 15 18:30:52 EDT 2008
I saw the various demos using common data and a common look & feel but otherwise being
relatively autonomous. They would live in svn (the code at least). Bugs would be trac'd
as a separate component. Just not sure how to handle the data. I suppose it could live as
a package in svn too. The demo would need to be installed someplace for access, that is,
we need a host with MapServer (with a number of features built), MapScript and PostGIS
(if we want to demo that as a data source).
Steve
>>> On 5/15/2008 at 10:11 AM, in message
<2DC5CCA14756424BBBEE8B4B2E4A682F036CF2F3 at ecburexch1.ontario.int.ec.gc.ca>,
"Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
> Steve: I think this is a good start. Awhile back we talked of merging
> the various demos into the OSGeo i/f (trac, svn). Much of the OGC
> workshop can feed the applicable bits in your TOC. How do you see the
> various demos working together (how modular or integrated)?
> ..Tom
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Steve Lime
>> Sent: 14 May, 2008 9:29 PM
>> To: mapserver-dev at lists.osgeo.org
>> Subject: [mapserver-dev] New demo proposal...
>> Hi all: I'm working on a new demo or more accurately a series
>> of demos. My thought is to extend the DNR test suite concept
>> which attempts to show off functionality and configuration
>> through a series of focused examples as opposed to a single
>> monolithic demo. The demos would be organized topically
>> (labeling, cartography, data formats, etc...) and could be
>> added to over time. A couple of other projects I checked out
>> use similar strategies. All examples would have browsable
>> mapfiles etc... and a choice few could be downloadable
>> individually in an archive format.
>> This could easily be expanded to as necessary and could serve
>> as live examples for tutorials, the downloadable manual Jeff
>> is working on and even the syntax manuals where is makes
>> sense. This could also be home to speed test cases and other
>> regression tests.
>> I'm thinking this would be hosted someplace, not sure where.
>> OSGeo servers maybe? Not sure about a data source yet either.
>> The Grass Spearfish data might work but I doubt it would
>> cover all the use cases we need although special formats and
>> derived products could created from it.
>> I've attached demo table of contents as a starting point.
>> Please let me know what you think...
>> Steve
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
