[mapserver-dev] Problem with label angle since v5.0
Steve Lime Steve.Lime at dnr.state.mn.us
Thu May 22 17:44:42 EDT 2008
Hi Tommy: I guess I'm not clear on what you're after. Bindings are evaluated on a feature by feature basis
during rendering so the value for the label will change repeatedly. In what context would you want to see
the angle?
Steve
>>> On 5/22/2008 at 10:42 AM, in message
<7b2d12b90805220842wb1c7c9dm6d9065040f1d8709 at mail.gmail.com>, "Tommy Roughol"
<nerkeilenemon at gmail.com> wrote:
> Hello,
> I have a problem since the release of Map Server 5. I now set the angle of
> my LabelObj with $oLabelObj->setBinding(MS_LABEL_BINDING_ANGLE, ...) .
> Nevertheless, I can't get the value of my LabelObj, because
> $oLabelObj->angle is a double, with value = 0, and there is no method
> getBinding(). Is there a way to get the value of the angle string in my
> label ? A method, a void, or anything else ?
> Thank You.
