[mapserver-dev] Mapserver v5.2 ArcSDE point layer prob
Graham Davis gdavis at refractions.net
Tue Nov 18 11:38:40 EST 2008
I brought this problem up in the mapserver IRC channel last week, and
have some more info regarding it.  Basically I've built Mapserver v5.2
for a client on Windows as they wish to upgrade from v4.10.  With the
new version, none of the their ArcSDE point layers work.  But polygon
and other types seem to work fine with SDE.  All of the problem point
layers worked fine in version 4.10 (the only thing that has changed is
the new mapserver).
I've since built them version 5.0 for them to test with (to try and
narrow down where the problem was introduced).  This version works fine
for SDE point layers.  So something has changed between versions 5.0 and
5.2 to prevent SDE point layers from working.  The error message they
receive is:
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named 'DBM_7H_MIL_POPULATION_POINT'.
msDrawShape(): General error message. Unknown layer type.
</ServiceException>
</ServiceExceptionReport>
Anyone have any idea what is going wrong, or where I can officially post this bug?  A snipet of the map file layer definition is attached.  Thanks,
Graham Davis
Refractions Research Inc.
    LAYER
      NAME DBM_7H_MIL_POPULATION_POINT
      TYPE point
      CONNECTION "<removed>"
      CONNECTIONTYPE sde
      DATA "WHSE_BASEMAPPING.DBM_7H_MIL_POPULATION_POINT,GEOMETRY"
      STATUS ON
      MINSCALEDENOM 100
      MAXSCALEDENOM 20000000
      PROJECTION
         "init=epsg:3005"
       END
      # CLASS object
          CLASS
            NAME "points_green"
            SYMBOL "gps_coordinate-green"
            COLOR 255 0 0
            # LABEL object
            LABEL
              POSITION CC
              SIZE TINY
              MINDISTANCE 400
              MINFEATURESIZE 5
              COLOR 255 255 255
              PARTIALS FALSE
            END
          END
    END #end layer
