[mapserver-dev] Time for a 5.2.1 release?
Daniel Morissette
dmorissette at mapgears.com
Wed Nov 19 08:49:08 EST 2008
I'd say we release 5.2.1 with what's in SVN already and those two
tickets can wait for 5.4 or 5.2.2 since if they were high enough
priority they would be fixed already.
Daniel
Kralidis,Tom [Ontario] wrote:
> Any update on this? Looks like
> http://trac.osgeo.org/mapserver/ticket/2781 and
> http://trac.osgeo.org/mapserver/ticket/2657 are tickets of interest to
> fix for a 5.2.1 rel.
> ..Tom
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
>> Jeff McKenna
>> Sent: Monday, October 20, 2008 10:28 AM
>> To: MapServer Dev Mailing List
>> Subject: Re: [mapserver-dev] Time for a 5.2.1 release?
>> I'd recommend the 5.2.1 release happens in the next couple of weeks.
>> (sooner than later is better for me) Thoughts?
>> -jeff
>> Steve Lime wrote:
>>> It's ok with me. Any chance of sneaking
>> http://trac.osgeo.org/mapserver/ticket/2781 in?
>>> Steve
>>>>>> On 9/29/2008 at 8:17 AM, in message
>> <2DC5CCA14756424BBBEE8B4B2E4A682F03BCC59B at ecburexch1.ontario.int.ec.gc
>>> .ca>, "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
>>>> I would like to see
>> http://trac.osgeo.org/mapserver/ticket/2657 fixed
>>>> (I believe the patch will do it), otherwise, I thank 5.2.1
>> this week
>>>> is a good idea.
>>>> ..Tom
>>>> From: mapserver-dev-bounces at lists.osgeo.org on behalf of Daniel
>>>> Morissette
>>>> Sent: Mon 29-Sep-08 09:15
>>>> To: 'MapServer Dev Mailing List'
>>>> Subject: [mapserver-dev] Time for a 5.2.1 release?
>>>> We seem to have a good set of fixes in the 5.2 branch in
>> SVN. What do
>>>> you all think of a 5.2.1 release this week with what's in
>> there now?
>>>> Daniel
>>>> Current Version (SVN branch-5-2)
>>>> - Fixed bug when QUERYMAP hilite color is set and the
>> shape's color in a
>>>> layer is from a data source (#2769)
>>>> - PHP paste image should also work with AGG (#2682)
>>>> - Correct allocation error in mapmssql2008.c (#2768)
>>>> - Removed comma to correct WCS 1.1 Coverages formatting in payload
>>>> directory.
>>>> (#2764)
>>>> - Correct bug when LABEL_NO_CLIP in combination with
>> minfeaturesize
>>>> (#2758)
>>>> - Fix a label size computation for AGG bug when
>> scalefactor is used
>>>> (#2756)
>>>> - Got rid of misleading errors about OWS SERVICE not being
>> compiled in
>>>> when a OWS request is sent that includes mode=map (or
>> other mode value
>>>> different from ows)(#2747)
>>>> - Fixed a memory leak associated with not deleting the lexer buffer
>>>> before parsing certain types of strings. (#2729)
>>>> - Masking the out-of-range characters to avoid the crash
>>>> in the AGG renderer (#2739)
>>>> - AGG: fix pixmap symbols not drawing if no color was specified
>>>> (#2736)
>>>> - Accept WMS requests in which the optional SERVICE param
>> is missing.
>>>> A new test was incorrectly added in 5.2.0 that resulted
>> in the error
>>>> "Incomplete WFS request: SERVICE parameter missing"
>> when the SERVICE
>>>> parameter was missing in WMS requests in which the
>> SERVICE param is
>>>> optional (#2737)
>>>> - SLD: when creating well known symbols on the fly the pen-up value
>>>> used should be -99.
>>>> - Support reading projection parameter for OFC filters (#2712)
>>>> - Stop configure execution with an error if path to one of
>> the -config
>>>> scripts is invalid (#2710)
>>>> - Fixed the configure script: failed to detect php5 on ubuntu.
>>>> (#2365)
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
