RE: [mapserver-dev] Time for a 5.2.1 release?
aboudreault at mapgears.com
Wed Nov 19 08:54:31 EST 2008
The ticket 2781 is done, it just need to be retested and commited in trunk. It could be add this week if needed.
Alan
-----Original Message-----
From: "Kralidis,Tom [Ontario]" <Tom.Kralidis at ec.gc.ca>
Sent: Wednesday, November 19, 2008 8:32am
To: mapserver-dev at lists.osgeo.org
Subject: RE: [mapserver-dev] Time for a 5.2.1 release?
Any update on this? Looks like
http://trac.osgeo.org/mapserver/ticket/2781 and
http://trac.osgeo.org/mapserver/ticket/2657 are tickets of interest to
fix for a 5.2.1 rel.
..Tom
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> Jeff McKenna
> Sent: Monday, October 20, 2008 10:28 AM
> To: MapServer Dev Mailing List
> Subject: Re: [mapserver-dev] Time for a 5.2.1 release?
> I'd recommend the 5.2.1 release happens in the next couple of weeks.
> (sooner than later is better for me) Thoughts?
> -jeff
> Steve Lime wrote:
> > It's ok with me. Any chance of sneaking
> http://trac.osgeo.org/mapserver/ticket/2781 in?
> > Steve
> >>>> On 9/29/2008 at 8:17 AM, in message
> <2DC5CCA14756424BBBEE8B4B2E4A682F03BCC59B at ecburexch1.ontario.int.ec.gc
> > .ca>, "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
> >> I would like to see
> http://trac.osgeo.org/mapserver/ticket/2657 fixed
> >> (I believe the patch will do it), otherwise, I thank 5.2.1
> this week
> >> is a good idea.
> >> ..Tom
> >> From: mapserver-dev-bounces at lists.osgeo.org on behalf of Daniel
> >> Morissette
> >> Sent: Mon 29-Sep-08 09:15
> >> To: 'MapServer Dev Mailing List'
> >> Subject: [mapserver-dev] Time for a 5.2.1 release?
> >> We seem to have a good set of fixes in the 5.2 branch in
> SVN. What do
> >> you all think of a 5.2.1 release this week with what's in
> there now?
> >> Daniel
> >> Current Version (SVN branch-5-2)
> >> - Fixed bug when QUERYMAP hilite color is set and the
> shape's color in a
> >> layer is from a data source (#2769)
> >> - PHP paste image should also work with AGG (#2682)
> >> - Correct allocation error in mapmssql2008.c (#2768)
> >> - Removed comma to correct WCS 1.1 Coverages formatting in payload
> >> directory.
> >> (#2764)
> >> - Correct bug when LABEL_NO_CLIP in combination with
> minfeaturesize
> >> (#2758)
> >> - Fix a label size computation for AGG bug when
> scalefactor is used
> >> (#2756)
> >> - Got rid of misleading errors about OWS SERVICE not being
> compiled in
> >> when a OWS request is sent that includes mode=map (or
> other mode value
> >> different from ows)(#2747)
> >> - Fixed a memory leak associated with not deleting the lexer buffer
> >> before parsing certain types of strings. (#2729)
> >> - Masking the out-of-range characters to avoid the crash
> >> in the AGG renderer (#2739)
> >> - AGG: fix pixmap symbols not drawing if no color was specified
> >> (#2736)
> >> - Accept WMS requests in which the optional SERVICE param
> is missing.
> >> A new test was incorrectly added in 5.2.0 that resulted
> in the error
> >> "Incomplete WFS request: SERVICE parameter missing"
> when the SERVICE
> >> parameter was missing in WMS requests in which the
> SERVICE param is
> >> optional (#2737)
> >> - SLD: when creating well known symbols on the fly the pen-up value
> >> used should be -99.
> >> - Support reading projection parameter for OFC filters (#2712)
> >> - Stop configure execution with an error if path to one of
> the -config
> >> scripts is invalid (#2710)
> >> - Fixed the configure script: failed to detect php5 on ubuntu.
> >> (#2365)
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
