[mapserver-dev] Time for a 5.2.1 release?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Nov 19 12:02:33 EST 2008
+1
Kralidis,Tom [Ontario] wrote:
> Fair enough. +1
> ..Tom
>> -----Original Message-----
>> From: Daniel Morissette [mailto:dmorissette at mapgears.com]
>> Sent: Wednesday, November 19, 2008 8:49 AM
>> To: Kralidis,Tom [Ontario]
>> Cc: mapserver-dev at lists.osgeo.org
>> Subject: Re: [mapserver-dev] Time for a 5.2.1 release?
>> I'd say we release 5.2.1 with what's in SVN already and those
>> two tickets can wait for 5.4 or 5.2.2 since if they were high
>> enough priority they would be fixed already.
>> Daniel
>>> Any update on this? Looks like
>>> http://trac.osgeo.org/mapserver/ticket/2781 and
>>> http://trac.osgeo.org/mapserver/ticket/2657 are tickets of
>> interest to
>>> fix for a 5.2.1 rel.
>>> ..Tom
>>>> From: mapserver-dev-bounces at lists.osgeo.org
>>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff
>>>> McKenna
>>>> Sent: Monday, October 20, 2008 10:28 AM
>>>> To: MapServer Dev Mailing List
>>>> I'd recommend the 5.2.1 release happens in the next couple
>> of weeks.
>>>> (sooner than later is better for me) Thoughts?
>>>> -jeff
>>>> Steve Lime wrote:
>>>>> It's ok with me. Any chance of sneaking
>>>> http://trac.osgeo.org/mapserver/ticket/2781 in?
>>>>> Steve
>>>>>>>> On 9/29/2008 at 8:17 AM, in message
>> <2DC5CCA14756424BBBEE8B4B2E4A682F03BCC59B at ecburexch1.ontario.int.ec.g
>>>> c
>>>>> .ca>, "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
>>>>>> I would like to see
>>>> http://trac.osgeo.org/mapserver/ticket/2657 fixed
>>>>>> (I believe the patch will do it), otherwise, I thank 5.2.1
>>>> this week
>>>>>> is a good idea.
>>>>>> ..Tom
>>>>>> From: mapserver-dev-bounces at lists.osgeo.org on behalf of Daniel
>>>>>> Morissette
>>>>>> Sent: Mon 29-Sep-08 09:15
>>>>>> To: 'MapServer Dev Mailing List'
>>>>>> Subject: [mapserver-dev] Time for a 5.2.1 release?
>>>>>> We seem to have a good set of fixes in the 5.2 branch in
>>>> SVN. What do
>>>>>> you all think of a 5.2.1 release this week with what's in
>>>> there now?
>>>>>> Daniel
>>>>>> Current Version (SVN branch-5-2)
>>>>>> - Fixed bug when QUERYMAP hilite color is set and the
>>>> shape's color in a
>>>>>> layer is from a data source (#2769)
>>>>>> - PHP paste image should also work with AGG (#2682)
>>>>>> - Correct allocation error in mapmssql2008.c (#2768)
>>>>>> - Removed comma to correct WCS 1.1 Coverages formatting
>> in payload
>>>>>> directory.
>>>>>> (#2764)
>>>>>> - Correct bug when LABEL_NO_CLIP in combination with
>>>> minfeaturesize
>>>>>> (#2758)
>>>>>> - Fix a label size computation for AGG bug when
>>>> scalefactor is used
>>>>>> (#2756)
>>>>>> - Got rid of misleading errors about OWS SERVICE not being
>>>> compiled in
>>>>>> when a OWS request is sent that includes mode=map (or
>>>> other mode value
>>>>>> different from ows)(#2747)
>>>>>> - Fixed a memory leak associated with not deleting the
>> lexer buffer
>>>>>> before parsing certain types of strings. (#2729)
>>>>>> - Masking the out-of-range characters to avoid the crash
>>>>>> in the AGG renderer (#2739)
>>>>>> - AGG: fix pixmap symbols not drawing if no color was specified
>>>>>> (#2736)
>>>>>> - Accept WMS requests in which the optional SERVICE param
>>>> is missing.
>>>>>> A new test was incorrectly added in 5.2.0 that resulted
>>>> in the error
>>>>>> "Incomplete WFS request: SERVICE parameter missing"
>>>> when the SERVICE
>>>>>> parameter was missing in WMS requests in which the
>>>> SERVICE param is
>>>>>> optional (#2737)
>>>>>> - SLD: when creating well known symbols on the fly the
>> pen-up value
>>>>>> used should be -99.
>>>>>> - Support reading projection parameter for OFC filters (#2712)
>>>>>> - Stop configure execution with an error if path to one of
>>>> the -config
>>>>>> scripts is invalid (#2710)
>>>>>> - Fixed the configure script: failed to detect php5 on ubuntu.
>>>>>> (#2365)
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Daniel Morissette
>> http://www.mapgears.com/
