[mapserver-dev] MapServer vs character encodings
Daniel Morissette
dmorissette at mapgears.com
Tue Nov 25 09:02:18 EST 2008
Howard Butler wrote on mapserver-users:
> Yes, I was asking if this was an NSTRING column or a STRING column. The
> MapServer ArcSDE code makes an attempt to transcode the data if it is an
> nstring column, but it is highly likely this is broken. I didn't have
> very extensive data to test this with, and all I looked to ensure was
> that a few pictures looked right. The problem might be as simple as the
> function msConvertWideStringToUTF8 being broken. Here's where MapServer
> tries to convert it:
> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapsde.c#L750
> The reason that this is such a problem is that MapServer doesn't really
> have its unicode/wide character strategy well defined. ArcSDE forces the
> issue on us now because by default they're using nstring columns for
> loading data by default, so the ArcSDE users are on the front lines of
> this, but I think it will be more of a problem as time marches on.
> Questions the MapServer devs need to answer are:
> - how are strings to be internally represented in MapServer (lots of
> things to balance by answering this question)?
> - who is responsible for transforming the data? The driver for both the
> in and out? Have a smarter string object that carries its own encoding
> around?
> - Unicode is a conspiracy :)
I copied this to the -dev list to see if anyone had ideas. It's an ugly
problem that none of us wants to touch and seems to hit SDE users mostly
at this point.
Honestly I am not sure I understand the issue with SDE that Howard
describes. Would it not be enough to require that data access drivers
that read data in unicode transform all attribute values to UTF-8? I
thought that was what the SDE driver was doing and honestly don't
understand why that doesn't work.
Daniel
Daniel Morissette
http://www.mapgears.com/
