[mapserver-dev] map imagecolor not working with agg/png
John Cole
jcole at carinatek.com
Wed Oct 1 12:04:48 EDT 2008
I have a map file that I'm setting the image color on. It works with
the agg/jpeg driver, but not the agg/png driver.
Here are my output sections:
OUTPUTFORMAT
NAME "png"
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
OUTPUTFORMAT
NAME "png24"
DRIVER "AGG/PNG"
MIMETYPE "image/png; mode=24bit"
IMAGEMODE RGBA
EXTENSION "png"
END
OUTPUTFORMAT
NAME "JPEG"
DRIVER "AGG/JPEG"
IMAGEMODE RGB
FORMATOPTION "QUALITY=95"
END
And my image color section is:
STATUS ON
SIZE 600 400
EXTENT -128.2 16.9 -65.2 58.9
UNITS DD
IMAGECOLOR 156 188 217
IMAGETYPE png
If I change IMAGETYPE to jpeg, then the background is set correctly.
I'm using MS4W 2.3.0 on Windows 2008 Server.
MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICO
NV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
SUPPORTS=FASTCGI SUP
PORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS
INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
I checked current bugs and nabbled the list but didn't see a mention of
an issue here. Do I have to set something in the png output for the
background image to work?
Thanks,
John
Type: image/jpeg
Desc: ms4w.2.3.0.jpg
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081001/5ff5ffcb/ms4w.2.3.0-0001.jpg
Type: image/png
Desc: ms4w.2.3.0.png
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081001/5ff5ffcb/ms4w.2.3.0-0001.png
