[mapserver-dev] Memory Leak
Ned Harding nharding at extendthereach.com
Fri Oct 3 17:02:24 EDT 2008
There is a memory leak in msInsertLayer.  The below patch fixes it.  Can
someone else review it and tell me what I should do with it?
Thanks,
Ned.
Index: S:/3rdParty/GIS/MapServer/mapobject.c
--- S:/3rdParty/GIS/MapServer/mapobject.c       (revision 15750)
+++ S:/3rdParty/GIS/MapServer/mapobject.c     (working copy)
@@ -498,10 +498,20 @@
     /* Ensure there is room for a new layer */
-    if (msGrowMapLayers(map) == NULL)
-        return -1;
-    /* Catch attempt to insert past end of layers array */
-    else if (nIndex >= map->numlayers) {
+    if (map->numlayers == map->maxlayers)
+                              if (msGrowMapLayers(map) == NULL)
+                                              return -1;
+              /* msGrowMapLayers allocates the new layer which we don't
need to do since we have 1 that we are inserting
+                              not sure if it is possible for this to be
non null otherwise, but better to check since this function
+                              replaces the value */
+              if (map->layers[map->numlayers]!=NULL)
+                              free(map->layers[map->numlayers]);
+              /* Catch attempt to insert past end of layers array */
+              if (nIndex >= map->numlayers) {
         msSetError(MS_CHILDERR, "Cannot insert layer beyond index %d",
                    "msInsertLayer()", map->numlayers-1);
         return -1;
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20081003/b28acce6/attachment.html
