[mapserver-dev] strange problem with WFS and ArcSDE layers
bartvde at osgis.nl
bartvde at osgis.nl
Wed Oct 8 07:17:40 EDT 2008
Okay, after some debugging I found this is caused by mapwfs.c, the
following line:
bbox = map->extent = ext;
it changes the map extent to the layer's extent, but since the queries are
run in another loop, this is a global setting and the map extent will have
the extent of the last query layer.
This changeset introduced this:
http://trac.osgeo.org/mapserver/changeset/7674
Tom, are you able to comment on this?
Best regards,
Bart
> Hi list,
> does anyone have an idea why the sequence of Query elements in the WFS
> request is influencing my result?
> Something like:
> <GetFeature service="WFS" version="1.0.0"
> xmlns="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://schemas.opengis.net/wfs/1.0.0 WFS-basic.xsd">
> <Query typeName="KGNAT.LOEVER">
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> <ogc:PropertyIsLike wildCard="*" singleChar="." escape="!">
> <ogc:PropertyName>CODEBPN</ogc:PropertyName>
> <ogc:Literal>*KST1.OO.-.23.ov*</ogc:Literal>
> </ogc:PropertyIsLike>
> </ogc:Filter>
> </Query>
> <Query typeName="KGNAT.VOEVER">
> </ogc:Filter>
> </Query>
> </GetFeature>
> yields 1 result which is correct.
> If I change the sequence, so first VOEVER and then LOEVER, I get:
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <wfs:FeatureCollection
> xmlns:rws="http://mapserver.gis.umn.edu/mapserver"
> xmlns:wfs="http://www.opengis.net/wfs"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> http://test.intranet.rijkswaterstaat.nl/services/geoservices/kerngisnat_noho?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=KGNAT.VOEVER,KGNAT.LOEVER&OUTPUTFORMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:null>missing</gml:null>
> </gml:boundedBy>
> </wfs:FeatureCollection>
> Using 5.2, and running out of ideas .... TIA.
> Best regards,
> Bart
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
