[mapserver-dev] Time for a 5.2.1 release?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Oct 20 10:27:45 EDT 2008
I'd recommend the 5.2.1 release happens in the next couple of weeks.
(sooner than later is better for me) Thoughts?
-jeff
Steve Lime wrote:
> It's ok with me. Any chance of sneaking http://trac.osgeo.org/mapserver/ticket/2781 in?
> Steve
>>>> On 9/29/2008 at 8:17 AM, in message
> <2DC5CCA14756424BBBEE8B4B2E4A682F03BCC59B at ecburexch1.ontario.int.ec.gc.ca>,
> "Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
>> I would like to see http://trac.osgeo.org/mapserver/ticket/2657 fixed (I
>> believe the patch will do it), otherwise, I thank 5.2.1 this week is a good
>> idea.
>> ..Tom
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org on behalf of Daniel Morissette
>> Sent: Mon 29-Sep-08 09:15
>> To: 'MapServer Dev Mailing List'
>> Subject: [mapserver-dev] Time for a 5.2.1 release?
>> We seem to have a good set of fixes in the 5.2 branch in SVN. What do
>> you all think of a 5.2.1 release this week with what's in there now?
>> Daniel
>> Current Version (SVN branch-5-2)
>> - Fixed bug when QUERYMAP hilite color is set and the shape's color in a
>> layer is from a data source (#2769)
>> - PHP paste image should also work with AGG (#2682)
>> - Correct allocation error in mapmssql2008.c (#2768)
>> - Removed comma to correct WCS 1.1 Coverages formatting in payload
>> directory.
>> (#2764)
>> - Correct bug when LABEL_NO_CLIP in combination with minfeaturesize (#2758)
>> - Fix a label size computation for AGG bug when scalefactor is used (#2756)
>> - Got rid of misleading errors about OWS SERVICE not being compiled in
>> when a OWS request is sent that includes mode=map (or other mode value
>> different from ows)(#2747)
>> - Fixed a memory leak associated with not deleting the lexer buffer
>> before parsing certain types of strings. (#2729)
>> - Masking the out-of-range characters to avoid the crash
>> in the AGG renderer (#2739)
>> - AGG: fix pixmap symbols not drawing if no color was specified (#2736)
>> - Accept WMS requests in which the optional SERVICE param is missing.
>> A new test was incorrectly added in 5.2.0 that resulted in the error
>> "Incomplete WFS request: SERVICE parameter missing" when the SERVICE
>> parameter was missing in WMS requests in which the SERVICE param is
>> optional (#2737)
>> - SLD: when creating well known symbols on the fly the pen-up value
>> used should be -99.
>> - Support reading projection parameter for OFC filters (#2712)
>> - Stop configure execution with an error if path to one of the -config
>> scripts is invalid (#2710)
>> - Fixed the configure script: failed to detect php5 on ubuntu. (#2365)
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
