[mapserver-dev] Attempt to fix #1706
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Wed Sep 17 15:14:18 EDT 2008
AFAIKT, it looks perfectly fine to me.
Thanks,
Peter
Yewondwossen Assefa wrote:
> Peter,
>  I have reviewed and done a couple of modifications to the patch
> proposed in the bug. Please verify the comments in the bug. I would
> then commit the changes.
> Best Regards,
> Peter Hopfgartner wrote:
>> Hello
>> Could the following patch be applied?
>> http://trac.osgeo.org/mapserver/attachment/ticket/1706/mapsvg.c.diff
>> Anyway, there is a minor issue with this patch. Since it writes all
>> path coordinates with 2 digits after the comma, it inflates the file
>> size of teh SVG file, even if full resolution is not wanted.
>> Unfortunatly, I do not know, how to guess this setting from within
>> function mapsvg.c:imagePolyline(). I could make the variable bFullRes
>> module wide and set the parameter from mapsvg.c:msTransformShapeSVG().
>> Regards,
>> Peter
>> R3 GIS
>> http://www.r3-gis.com
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
