[mapserver-dev] Labelling problem using mapserver with ka-map
SUSANNE
susanne.kalliany at tefis.at
Fri Sep 19 06:58:44 EDT 2008
Dear mapserver-community,
I already had some discussion on my particular problem under the
thread "Ok, one more labeling sample...", but even Steve Lime
had no solution which will work in any case. His last statement was:
> Ka-map is DHTML layer driven so you're definitely seeing the side
> effects of overlaying antialiased, transparent
> output on a background. The anti-aliasing occurs on a white background
> in the vector map which is why you see
> the white artifacts around your text. I'm not sure there is a perfect
> fix, variable opacity with 24-bit out put is the
> answer but not all browsers support it.
Does anybody have experience in this field?
My first statement was:
How can I get rid of the white "shadows" accompanying all letters ?
http://www.nabble.com/file/p19570283/SNAG-000.jpg
Here is the signifanct part of my map-file:
LAYER
NAME Kataster_region
GROUP Kataster
STATUS OFF
MAXSCALE 300000
TYPE POLYGON
DATA 'd:/ewald/Kataster_OOE/45416GST'
LABELITEM 'GNR'
CLASS
STYLE
OUTLINECOLOR 255 0 255
WIDTH 1
END
LABEL
TYPE TRUETYPE
FONT 'sans'
SIZE 8
POSITION cc
Color 0 0 0
END
END
TEMPLATE 'dummy.html'
END
thanks, Susanne
View this message in context: http://www.nabble.com/Labelling-problem-using-mapserver-with-ka-map-tp19570283p19570283.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
