[mapserver-dev] Time for a 5.2.1 release?
Steve Lime Steve.Lime at dnr.state.mn.us
Mon Sep 29 12:33:20 EDT 2008
It's ok with me. Any chance of sneaking http://trac.osgeo.org/mapserver/ticket/2781 in?
Steve
>>> On 9/29/2008 at 8:17 AM, in message
<2DC5CCA14756424BBBEE8B4B2E4A682F03BCC59B at ecburexch1.ontario.int.ec.gc.ca>,
"Kralidis,Tom [Burlington]" <Tom.Kralidis at ec.gc.ca> wrote:
> I would like to see http://trac.osgeo.org/mapserver/ticket/2657 fixed (I
> believe the patch will do it), otherwise, I thank 5.2.1 this week is a good
> idea.
> ..Tom
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org on behalf of Daniel Morissette
> Sent: Mon 29-Sep-08 09:15
> To: 'MapServer Dev Mailing List'
> Subject: [mapserver-dev] Time for a 5.2.1 release?
> We seem to have a good set of fixes in the 5.2 branch in SVN. What do
> you all think of a 5.2.1 release this week with what's in there now?
> Daniel
> Current Version (SVN branch-5-2)
> - Fixed bug when QUERYMAP hilite color is set and the shape's color in a
>    layer is from a data source (#2769)
> - PHP paste image should also work with AGG (#2682)
> - Correct allocation error in mapmssql2008.c (#2768)
> - Removed comma to correct WCS 1.1 Coverages formatting in payload
> directory.
>    (#2764)
> - Correct bug when LABEL_NO_CLIP in combination with minfeaturesize (#2758)
> - Fix a label size computation for AGG bug when scalefactor is used (#2756)
> - Got rid of misleading errors about OWS SERVICE not being compiled in
>    when a OWS request is sent that includes mode=map (or other mode value
>    different from ows)(#2747)
> - Fixed a memory leak associated with not deleting the lexer buffer
>    before parsing certain types of strings. (#2729)
> - Masking the out-of-range characters to avoid the crash
>    in the AGG renderer (#2739)
> - AGG: fix pixmap symbols not drawing if no color was specified (#2736)
> - Accept WMS requests in which the optional SERVICE param is missing.
>    A new test was incorrectly added in 5.2.0 that resulted in the error
>    "Incomplete WFS request: SERVICE parameter missing" when the SERVICE
>    parameter was missing in WMS requests in which the SERVICE param is
>    optional (#2737)
> - SLD: when creating well known symbols on the fly the pen-up value
>    used should be -99.
> - Support reading projection parameter for OFC filters (#2712)
> - Stop configure execution with an error if path to one of the -config
>    scripts is invalid (#2710)
> - Fixed the configure script: failed to detect php5 on ubuntu. (#2365)
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
