[mapserver-dev] Clarification on RFC 44 changes
Steve Lime
Steve.Lime at dnr.state.mn.us
Sun Apr 5 21:35:28 EDT 2009
In keeping with some of the security changes I think allowing changes to where
temp files are created is a bad idea, plain and simple. The only reason it was allowed
was to support the Itasca demo that used it to ease configuration. I was planning
on releasing a new version of that demo anyway for 5.4, it's time.
I can re-add those keywords if folks think it's ok, but I'd rather keep the changes
I made in beta4.
To answer the question, you can't do this in 5.4, you have to set the WEB object
correctly.
Steve
>>> thomas bonfort <thomas.bonfort at gmail.com> 04/04/09 8:45 AM >>>
Steve pulled a few keywords from what was allowed to be overridden:
http://trac.osgeo.org/mapserver/changeset/8858
thomas
On Sat, Apr 4, 2009 at 15:22, Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> I'm trying to understand the changes implemented in RFC#44 ("Restore URL
> modification of mapfiles to pre-5.0 levels").
> With MapServer 5.2.2 the following works:
> mapserv?map_web=imagepath+/ms4w/tmp/ms_tmp+imageurl+/ms_tmp/
> But with the MapServer 5.4.0 betas the following do not work:
> 1) post 5.0-way:
> Error: "getString(): Symbol definition error. Parsing error near
> (ms_tmp):(line 1)"
> 2) pre 5.0-way:
> mapserv?map_web_imagepath=/ms4w/tmp/ms_tmp&map_web_imageurl=/ms_tmp/
> Error: "loadWeb()Unknown identifier. Parsing error near
> (/ms4w/tmp/ms_tmp/):(line 1)
> What is the correct way for 5.4.0 ???
> Other notes:
> - I have verified that the mapfile is valid in 5.4.0 with shp2img
> thanks.
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
