[mapserver-dev] RFC 54: Mapserver Rendering API
Brent Fraser bfraser at geoanalytic.com
Tue Apr 14 12:44:23 EDT 2009
Thomas,
  I'm going to compile the sandbox/graphics code on Windows XP using Visual Studio .NET 2003.  I expect there will be a few changes necessary to get it to compile.  How do you want to handle the changes?  Should I send them to you?
Thanks!
Brent Fraser
Thomas Bonfort wrote:
> Hi devs,
> RFC 54 has just been committed to the docs site:
> http://mapserver.org/development/rfc/ms-rfc-54.html
> I've tried to be as complete as possible, but I'm quite sure I may
> have missed a couple (I hope minor) points.
> Most of the RFC is implemented in the graphics sandbox. It  would be
> great if some of you could try it on your local mapfiles to squeeze
> out as many bugs as possible (currently not activated/implemented are
> symbology on lines and polygons, and all the raster layer related
> code).
> To enable the plugin code, you need to configure with --with-cairo.
> The outputformat drivers are cairo/png , cairo/jpeg, cairo/svg and
> cairo/pdf.
> Ideally I'd like to merge the graphics branch into the trunk around
> the end of the month so we have more eyes on it before our september
> release target.
> Best regards,
> thomas
