[mapserver-dev] RFC 54: MapServer Rendering API
toby.rahilly at gmail.com
Sun Apr 19 20:52:10 EDT 2009
I will update the Opengl to match the new vtable interface.
The FTGL package (http://ftgl.wiki.sourceforge.net/) is required for
rendering labels into OpenGL.
Cheers,
Toby
On Apr 20, 2009 4:24am, Tamas Szekeres <szekerest at gmail.com> wrote:
> I would rather in favour of merging the trunk back to the sandbox first,
> and do some testings in place (either by adding some stuff to the
> msautotest as well).
> Then if we get rid of the potential issues (build problems, memory
> corruptions, segfaults) we can safely add the stuff in the trunk
> permanently.
> Currently I find several issues either with the simplest mapfiles that
> should somehow be fixed first. The opengl support didn't work for me at
> all, it seems the implementation didn't follow the recent changes of the
> vtable names caused compiler errors. It may also be required to install
> some additional things that I'm currently not aware of.
> I've fixed up the most alloying issues and the sandbox now compiles on
> windows. I also advertised ready to use windows binary packages for the
> users to be able to test with on the mapserver-users list.
> Best regards,
> Tamas
> 2009/4/19 Steve Lime Steve.Lime at dnr.state.mn.us>
> My feeling is we should go with the merge now and work out any details
> where
> there are divergent paths (such as caching) later. We need this addition.
> Some
> of my comments were related to detail such as:
> - how should renderer options be encoded in an output format (presumably
> not
> as a format option, perhaps a new renderer option (hash?))
> - what will the make-up of the more specific rendering objects such as
> line styles
> look like?
> - reference maps are still necessary but I think we could attack them by
> turning a
> request for one into an internal mapfile and handing it off to the
> renderer.
> So, I'm +1 for the merge ASAP.
> Steve
> >>> thomas bonfort thomas.bonfort at camptocamp.com> 04/17/09 10:49 AM >>>
> Hi devs,
> RFC 54 has just been committed to the docs site:
> http://mapserver.org/development/rfc/ms-rfc-54.html
> I've tried to be as complete as possible, but I'm quite sure I may
> have missed a couple (I hope minor) points.
> Most of the RFC is implemented in the graphics sandbox. It would be
> great if some of you could try it on your local mapfiles to squeeze
> out as many bugs as possible (currently not activated/implemented are
> symbology on lines and polygons, and all the raster layer related code).
> To enable the plugin code, you need to configure with --with-cairo.
> The outputformat drivers are cairo/png , cairo/jpeg, cairo/svg and
> cairo/pdf.
> Ideally I'd like to merge the graphics branch into the trunk around
> the end of the month so we have more eyes on it before our september
> release target.
> Best regards,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090420/fb4882e4/attachment.html
