[mapserver-dev] Upper Limit to Number of Layers in Map file
Stephen Woodbridge woodbri at swoodbridge.com
Tue Apr 21 13:03:05 EDT 2009
Peter,
Are you using TILEINDEXs or are you puting every raster as a separate LAYER?
-Steve W
Peter Willis wrote:
> Hello,
> I am attempting to use mapserver as a WMS server for
> a large number of rasters.
> The system I am using has a collection of over 21000
> geo-referenced  rasters.
> These can be sorted into various groups, however
> any specific group of rasters may exceed 400 or more.
> I have tried modifying the value MS_MAXLAYERS in
> map.h and recompiling but am unsure if I will exceed
> the binary size of whatever variables are affected by
> that constant.
> What is the maximum, safe, binary size of the
> MS_MAXLAYERS constant that will not overflow
> the variables/procedures that use it?
> (ie: ulong32, ulong64, ushort16, uchar8,...???)
> Thanks for any insights,
> Peter
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
