[mapserver-dev] Using layers from different shapefilaes
jc_mich juan.michaca at paasel.com
Fri Apr 24 14:03:57 EDT 2009
Hello
I'm developing a SIG with Mapserver and Openlayers. I have several layers,
everyone are projected on UTM(WGS84), zone 14 north hemisphere.
In the beginning I used a shapefile which I've reprojected several times for
understanding geographical projections and it always works. Then I got other
geographic data files that were saved in tab files from MapInfo but they
were projected using different projections and I converted them into
shapefiles, using the projection above mentioned. Also I was wondering about
the integrity of those files.
I can overlap different layers using OpenLayers for vectors, markers etc.
But when I try to display a layer using the other shape files, they doesn't
display any map.
Is there anyone who've solved a similar problem, or a geographic expert who
can figure what I'm doing wrong?
Thanks in advance
View this message in context: http://n2.nabble.com/Using-layers-from-different-shapefilaes-tp2694309p2694309.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
