[mapserver-dev] AGG dependency: Call for vote
Perry Nacionales naci0002 at umn.edu
Tue Apr 28 15:23:04 EDT 2009
Yes, +1.  Thanks, Thomas.
-Perry
Thomas Bonfort wrote:
> Hi devs,
> this wasn't either explicit nor intended in my first email, so I'd
> like to formally call for vote on this one.
> We already have +1's from SteveL, SteveW and Assefa, and I'll add my +1 also.
> best regards,
> Thomas
> On Thu, Apr 23, 2009 at 8:02 AM, Thomas Bonfort
> <thomas.bonfort at camptocamp.com> wrote:
>> Devs,
>> I foresee this might by stirring a can of worms given the precedent
>> with the GD library, but I would like to propose that we stop relying
>> on an external agg library, and pull in our own subset of agg in the
>> mapserver source tree:
>> * most of the agg code is templated, which means that the agg external
>> library actually only contains a tiny subset of what we're using
>> anyways.
>> * building agg is a pain for our users (Makefile needs to be patched
>> (adding -fPIC and building a shared library), and some distro's
>> package are just plain broken (rhel notably). This is my primary
>> motivation for the modification.
>> * the design intent of the library was to be directly included in
>> project trees rather than being built as a library
>> * the agg project is to the least not very lively. It has been taken
>> over by the community, but for the time being this has limited itself
>> to having a large list of commiters but no actual coding going on. As
>> such I do not see it evolving in a near future.
>> * there would be no change in the mapserver code, only Makefile modifications.
>> If we decide to go down this route, I volunteer to maintain the
>> imported code and the corresponding Makefiles.
>> so:
>> - can the mapscript maintainers speak up if this can be disruptive ?
>> - bring on the flames :)
>> best regards,
>> thomas
>> www.camptocamp.com
>> +33 4 79 26 57 97
