[mapserver-dev] A question...
Daniel Morissette
dmorissette at mapgears.com
Thu Aug 6 10:58:25 EDT 2009
kiran varma wrote:
> In order to implement SVG functionality currently i am trying to mimic
> VECTOR rendering. Can someone explain the flow of control for the
> rendering of vector symbol? Preferably from mapfile parsing upto gd/agg
> rendering. This will help me understand the route that i have to take in
> order to render SVG symbol.
1- Parsing:
When the mapfile/symbolset is parsed, the symbol definitions is stored
in a symbolObj
2- At rendering time, msDrawMap() is called, which in turn calls
msDrawLayer() for each layer
3- For each shape read, msDrawShape() is called. This function contains
a switch/case statement based on layer type
The rest of the processing depends on the layer type and renderer. Let's
continue with the GD renderer:
4a- MS_LAYER_POINT: For a shape in a point layer, msDrawMarkerSymbol()
(which in turn calls msDrawMarkerSymbolGD() ) is called to draw the
symbol at the right location on the map based on the symbolObj
information. The point layer case is different from the two other layer
types because it doesn't use the symbol cache, the symbol is drawn
directly on top of the output image... I'm not exactly sure why, but
there is a TODO comment about this in the code.
4b- MS_LAYER_LINE: For a shape in a line layer, msDrawLineSymbol() is
called, which in turn calls msDrawLineSymbolGD(). Then
searchImageCache() is used to check if the symbol is already in the
cache for the current size, color and angle, and if not then
createBrush() is used to render the symbol in a and gdImagePtr, we store
it in the cache using addImageCache() and finally it is used as a brush
to render the line with gdImageLine().
4c - MS_LAYER_POLYGON: I leave that one to you as an exercise.
Hint: stepping through the code in GDB is an excellent way to figure the
flow of control of a given operation.
Daniel
Daniel Morissette
http://www.mapgears.com/
