[mapserver-dev] Creative Common embedded within WMS map
Deavi Purnomo
Deavi.Purnomo at landgate.wa.gov.au
Mon Aug 10 04:35:31 EDT 2009
Hi Mapserver Developer,
I have been trying to find out if "Creative Common" have been
incorporated to Mapserver WMS? If not, is there any future plan when
this is going to be incorporated in Mapserver WMS?
Thank you.
Regards,
Deavi Purnomo
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate’s liability is limited to re-supplying affected attachments.
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090810/fb0b5fb1/attachment.html
