[mapserver-dev] default values when using url overloading
Thomas Bonfort
thomas.bonfort at camptocamp.com
Fri Aug 28 08:11:04 EDT 2009
I've committed the changes to the code and documentation to support these
default values.
I've also added this support to shp2img, so that mapfiles with these default
values can be tested from the command line.
in order to use strncmp rather than strstr, the metadata keyword for these
parameters is
'default_keyword' 'value'
to get the default value of %keyword%
let me know if problems arise from these changes.
regards,
thomas
www.camptocamp.com
+33 5 16 57 01 02
On Sun, Aug 2, 2009 at 16:00, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Yeah, that would work, great suggestion. Feel free to add. I'd rather have
> multiple people
> work on code sections anyway. More eyes the better!
> Steve
> >>> Thomas Bonfort <thomas.bonfort at camptocamp.com> 08/01/09 3:21 AM >>>
> looking at the code, it seems like we could loop through metadata
> %key%_default_value entries to replace the value after having
> processed the url key/values, thus populating the strings with a
> default value if the entry was not found in the url.
> does this seem reasonable? if so I can take this, unless if Steve
> wants to keep the hand on that part of the code.
> cheers,
> thomas
> www.camptocamp.com
> +33 4 79 26 57 97
> On Wed, Jul 29, 2009 at 18:38, Steve Lime<Steve.Lime at dnr.state.mn.us>
> wrote:
> > Problem is that it's the presence of a parameter in the URL that causes
> the code to
> > check if something needs overloaded. So, for each url variable 'key' we
> look for %key%
> > in supported places and also apply validation (if supplied).
> > To do this we'd need to be able to define a list of supported keys and
> work through
> > that instead of the entire list passed as part of a request. With that it
> would be easy
> > to define a default somehow, likely through metadata.
> > Steve
> >>>> On 7/29/2009 at 10:52 AM, in message <4A70705A.2090403 at mapgears.com>,
> Daniel
> > Morissette <dmorissette at mapgears.com> wrote:
> >> Thomas Bonfort wrote:
> >>> I very often use url overloading with the %key% syntax in my mapfile
> >>> as I find it's a powerful means of building custom maps. The problem
> >>> with the current implementation is that the mapfile more often than
> >>> less becomes unparsable if the url doesn't contain the key=value
> >>> parameter.
> >>> Would it be complicated to modify the parser so that the mapfile can
> >>> contain a default value for %key%, that would be applied if the url
> >>> does not contain the "key" parameter?
> >> I have encountered that problem as well and think this would be a
> >> valuable addition.
> >> Perhaps it could be as simple as looking up the %key% value in metadata
> >> if it is not present in the URL?
> >> Daniel
> >> Daniel Morissette
> >> http://www.mapgears.com/
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> mapserver-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090828/2fe83719/attachment.html
