[mapserver-dev] labeling weirdness in trunk
Alan Boudreault aboudreault at mapgears.com
Fri Dec 11 09:36:38 EST 2009
Is the mapserv-52.png image supposed to be the expected result ? What's you
ANGLE setting for those labels ?
Alan
On December 11, 2009 09:25:55 am bartvde at osgis.nl wrote:
> Hi Steve,
> attached the trunk situation with lines (roads in green). In labeling.jpg.
> Btw, the change from 5.2 is also very strange, why are the labels not
> straight anymore but using an angle? I am using an SLD TextSymbolizer.
> Also the font size seems to have changed somehow from 5.2.
> Best regards,
> Bart
> > I don't think there have been changes in the labeling code. The placement
> > seems identical otherwise. I
> > can't tell where the North Sea is, but I'm assuming the N207 and N677
> > labels are in it. Since those don't
> > show up at all in the 5.6 image where are they supposed to be? Would be
> > helpful to see the line work the
> > labeling is based upon in the images.
> > Steve
> > ________________________________________
> > From: mapserver-dev-bounces at lists.osgeo.org
> > [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of bartvde at osgis.nl
> > [bartvde at osgis.nl]
> > Sent: Friday, December 11, 2009 3:17 AM
> > To: mapserver-dev at lists.osgeo.org
> > Subject: [mapserver-dev] labeling weirdness in trunk
> > Hi list,
> > we are experiencing some labeling weirdness (labels of roads in the North
> > Sea :-) ) in trunk compared to the 5.6 release.
> > Any idea what is causing this?
> > Best regards,
> > Bart
Alan Boudreault
Mapgears
http://www.mapgears.com
