[mapserver-dev] Toronto sprint hopes and dreams
Tamas Szekeres
szekerest at gmail.com
Wed Feb 4 10:15:49 EST 2009
Folks,
Unfortunately I won't be able to take part on this event, but I'm quite
interested in addressing this one pass query issue and will probably have a
working example by the time.
I'd also presume that the substantial changes would continue to have
accepted by the PSC according to RFC1 especially if the "When is vote
required?" section applies to that particular change in time before it gets
the final implementation.
In this regard I'd support having the significant additions to be manifested
in an RFC in time before the event is getting started since we normally
expect 2 business days before the final decision according to RFC1.
Best regards,
Tamas
2009/2/2 Paul Ramsey <pramsey at opengeo.org>
> One-pass query would be a good candidate for the sprint, since we
> could Big Bang the changes into lots of drivers at one go.
> P.
> PS - I hadn't realized the differences were so stark. The shapefile
> speed is what we should be expecting.
> On Mon, Feb 2, 2009 at 1:14 PM, Jim Klassen <Jim.Klassen at ci.stpaul.mn.us>
> wrote:
> > My goal is to speed up oraclespatial layers especially over WFS. (Right
> now a simple GetFeature with no filters takes 27min from an oraclespatial
> source, 2min 40 sec using ogr2ogr converting from the same table (via OCI)
> to GML. The same data takes 4min from PostGIS and 12 seconds from Shape via
> mapserver and WFS.)
> > Also there were at one point (I haven't checked in awhile) some bugs if
> there were differing coordinate systems for WFS and the MAP Projection
> object where the LatLon BBOX was calculated incorrectly that I would like to
> fix, if it hasn't been already.
> >>>> Paul Ramsey <pramsey at opengeo.org> 02/02/09 2:01 PM >>>
> > Resolution of the proj4/epsg/caching issues. Either with working code
> > or an agreed approach. It is the largest outstanding performance issue
> > for Mapserver.
> > On Mon, Feb 2, 2009 at 11:57 AM, Howard Butler <hobu.inc at gmail.com>
> wrote:
> >> I just wanted to start a thread for folks to toss around ideas for
> things
> >> they'd hope to accomplish for the Toronto sprint. Here's my list:
> >> - GetFeatureIDColumn vtable method
> >> http://lists.osgeo.org/pipermail/mapserver-dev/2009-January/008156.html
> >> - A prototype mod_mapserver http://trac.osgeo.org/mapserver/ticket/2565
> >> - Finish up website automation items
> >> What do you hope to start, finish, or work on during your sprint
> efforts?
> >> Howard
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> mapserver-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090204/6e3499a4/attachment-0001.html
