[Fwd: Re: [mapserver-dev] Any reaction to the 5.4 release plan?]
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Feb 4 12:17:57 EST 2009
Argh, this was supposed to go to the list.
-------- Original Message --------
Subject: Re: [mapserver-dev] Any reaction to the 5.4 release plan?
Date: Wed, 04 Feb 2009 11:12:35 -0500
From: Daniel Morissette <dmorissette at mapgears.com>
To: Stephen Woodbridge <woodbri at swoodbridge.com>
References: <498956DD0200008F000204B0 at co5.dnr.state.mn.us>
<4989AD43.6070107 at dmsolutions.ca> <4989B2FB.3000802 at mapgears.com>
<4989BDB9.8030102 at swoodbridge.com>
Steve, you sent this off-list, but I presume you meant to CC this to the
-dev list in support of not changing the dates currently in the release
plan?
Stephen Woodbridge wrote:
> Daniel,
> You have put into works exactly my concerns on this. I was thinking that
> we should start a 6.0 release plan so that high(er) risk changes can be
> pushed to that plan. My thought was to help set appropriate expectations
> for all involved. But I think your words better voice my concern than
> what I was going to propose above as an action plan to avoid the risk.
> -Steve W
> Daniel Morissette wrote:
>> Sorry for the lack of reply to your initial email. I liked the dates
>> that you had proposed (to release what's currently in SVN trunk by
>> early March) and didn't have much to add.
>> With respect to Assefa's comment, I thought it would be best to wrap
>> up 5.4 before the sprint so that we can focus on new/6.0 stuff in
>> Toronto. If 5.4 is still in the way and the source has not been
>> branched yet for 5.4 then I fear that will reduce our ability to make
>> real progress in the code sprint (i.e. major changes just before a
>> release is dangerous).
>> Daniel
>> Yewondwossen Assefa wrote:
>>> I was actually checking it and trying to understand if any of the
>>> work planned in Toronto will be part if the 5.4 release. From this
>>> schedule, It seems that it won't. I would propose to do a feature
>>> freeze at the end of the code sprint or shortly after so some things
>>> can fit in this 5.4 release.
>>> My main goals for the code print:
>>> - finalize my part for the 5.4 release
>>> - engage discussion the rendering (mainly pdf) in terms of having
>>> something suitable for a profession printing needs.
>>> Assefa
>>> Steve Lime wrote:
>>>> Not sure what absolute silence means...
>>>> http://trac.osgeo.org/mapserver/wiki/54ReleasePlan
>>>> Steve
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
