[mapserver-dev] PROJ4 and EPSG database
Daniel Morissette dmorissette at mapgears.com
Tue Feb 10 17:00:03 EST 2009
As we all know, PROJ4's processing of init files (the infamous epsg
file) is quite slow and a few options have been discussed on this list
to solve this, going from optimizations directly in PROJ to caching in
MapServer or even having MapServer use its own optimized database.
While working on WMS 1.3.0 we have come accross another need that
PROJ4's current init file setup doesn't address: the ability to lookup
extra information about a given SRS such as the axis order.
That gives one more argument for leaving the current PROJ4 init stuff
behind and developing an optimized (but simple) SRS database system.
I'd hate to do something specific to MapServer, so perhaps we could
develop a simple API that sits well on top of PROJ4 and that could be
used by all PROJ4-based applications to provide a shared projection
database format and API. We could even look at the database format used
by other systems such as GeoTools or GeoServer (I have no clue what they
use, just thinking out loud) so that we try sharing as much as possible
with them. I'd like to discuss that approach at the Toronto code sprint.
This is turning into a question for the MetaCRS project, but I wanted to
  run the idea by the MapServer group first since we are the ones with
the most pressing need for this.
Daniel
Daniel Morissette
http://www.mapgears.com/
