[mapserver-dev] Debugger for Mapserver
Mauricio Herrera georazor at gmail.com
Thu Feb 12 01:04:34 EST 2009
Hi Alan
Thanks for answering!
 Ok. I will get your tips...I will install GDB on my linux...
Sorry, I did not understand very well this: "You only need to build
Mapserver in debug mode" .. How can I do that? or where?  can you explain me
a little more??..pleaseee..
I am a little newbie, but I am a lot interested to develop source code for
Mapserver!!! =P
Mauricio
2009/2/11 Alan Boudreault <aboudreault at mapgears.com>
> Hi,
> You should be able to debug Mapserver with the most of debuggers. You only
> need to build Mapserver in debug mode. I use GDB and it works like a charm.
> Alan
> On February 11, 2009 04:56:27 am Mauricio Herrera wrote:
> > Hi developer list
> > Im looking for some kind of debugger for mapserver? could you help me?
> > Mainly I need to debug the next files: mapfile.c, mapfile.h mapfile.dtd
> > mapserv.c, mapserv.h...Because I want to modify and add some new
> > functions.. I have tried to debug with Builder c++ (graphical mode), but
> I
> > could not do that! when i try to debug they show me a lot errors ..I want
> > to know, how the developers did for developing the source code for
> > mapserver? I can not to (compile,run or debug) the  source code of
> > mapserver with the Builder c++
> > Pleeeeease help me
> > Thanks
> > Mauricio Herrera
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090211/27dd3341/attachment.html
