[mapserver-dev] scalehint max="0"
bartvde at osgis.nl
bartvde at osgis.nl
Tue Feb 17 04:47:58 EST 2009
Hi list,
following up on Daniel's post to wms-dev in 2001 [1].
Would it not be better to use a default value for max of e.g. INT_MAX
instead of 0?
<ScaleHint min="29.699871916217" max="0" />
<!-- WARNING: Only MINSCALEDENOM and no MAXSCALEDENOM specified in
the mapfile. A default value of 0 has been returned for the Max
ScaleHint but this is probably not what you want. -->
[1] http://lists.eogeo.org/pipermail/wms-dev/2001-August/000100.html
Best regards,
Bart
