[mapserver-dev] Problems building beta2...
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu Feb 26 11:01:02 EST 2009
Steve Lime wrote:
> Sorry, I can't test the Windows and the mac build was clean. Should we
> re-cut beta2 altogether
> or just build the windows version from the trunk (since this is just a
> build issue I'd favor the latter).
  I think it would be ok to have beta-2 on windows built against trunk.
> Steve
>>>> On 2/26/2009 at 8:09 AM, in message
> <49A6A2A7.4060401 at dmsolutions.ca>,
> Yewondwossen Assefa <yassefa at dmsolutions.ca> wrote:
>> This is fixed in trunk now. Sorry about that.
>> Note also that beta-2 does not build on windows. I committed the fix
> in
>> trunk.
>> Best Regards,
>> Steve Lime wrote:
>>> A real basic configure:
>>>   ./configure --with-agg=/usr/local/src/agg-2.4 --with-freetype
>>> bombs at build:
>>> mapogcsld.c: In function ‘msSLDGetGraphicSLD’:
>>> mapogcsld.c:3328: error: ‘OWS_1_0_0’ undeclared (first use in
> this
>>> function)
>>> mapogcsld.c:3328: error: (Each undeclared identifier is reported
> only
>>> once
>>> mapogcsld.c:3328: error: for each function it appears in.)
>>> mapogcsld.c: In function ‘msSLDGenerateLineSLD’:
>>> mapogcsld.c:3682: error: ‘OWS_1_0_0’ undeclared (first use in
> this
>>> function)
>>> mapogcsld.c: In function ‘msSLDGeneratePolygonSLD’:
>>> mapogcsld.c:3807: error: ‘OWS_1_0_0’ undeclared (first use in
> this
>>> function)
>>> mapogcsld.c: In function ‘msSLDGeneratePointSLD’:
>>> mapogcsld.c:3936: error: ‘OWS_1_0_0’ undeclared (first use in
> this
>>> function)
>>> mapogcsld.c: In function ‘msSLDGenerateTextSLD’:
>>> mapogcsld.c:3978: error: ‘OWS_1_0_0’ undeclared (first use in
> this
>>> function)
>>> Steve
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Assefa Yewondwossen
>> Software Analyst
>> Email: assefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax:   (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
