[mapserver-dev] setConnectionType(MS_WMS) doesn't work
Alexandre Dube
adube at mapgears.com
Thu Feb 26 11:42:14 EST 2009
Hi devs,
Any hint about this issue ?
Alexandre
Alexandre Dube wrote:
> Hi devs,
> I just installed mapserver 5.4.0-beta1. In mapscript, I'm now not
> unable to use oLayer->set("connectiontype", MS_WMS). I get an error
> saying "use setConnectionType()" instead.
> That's what I did, but it doesn't work with MS_WMS. My collegue
> Julien looked deeper in the code and found out in maplayer.c, in the
> msInitializeVirtualTable, when we use MS_WMS it returns MS_FAILURE.
> So I guess it's no longer possible to set connectiontype to wms in
> mapscript. Is there a new way of doing this ?
> Also, why would a normal mapfile still accept the wms CONNECTIONTYPE
> ? I tried to save my map object as a mapfile and only added
> CONNECTIONTYPE wms and it worked.
> Any hint ?
Alexandre Dubé
Mapgears
www.mapgears.com
