[mapserver-dev] setConnectionType(MS_WMS) doesn't work
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Feb 26 13:33:12 EST 2009
Alexandre,
I have opened a bug on it http://trac.osgeo.org/mapserver/ticket/2908)
with a patch. Can you please try the patch and see if it fixes your problem?
Thanks
PS Another note is I think $oLayer->setConnectionType return 0 on
success.
Best Regards,
Alexandre Dube wrote:
> Hi Assefa,
> I already set the type to raster before the call. See my code snippet
> (1).
> I attached the mapfile (mamap.map) my mapObject outputs. As you can
> see, both LAYER they don't have a CONNECTIONTYPE set. If I add it
> there, I get my images.
> Thanks a lot for your help,
> Alexandre
> (1) php mapscript snippet
> $oLayer = ms_newLayerObj($oMap);
> $oLayer->set("name", $szLayer);
> $oLayer->set("type", MS_LAYER_RASTER);
> $oLayer->set("status", MS_ON);
> $oLayer->set("connection", $szURL);
> //$oLayer->set("connectiontype", MS_WMS);
> $nStatus = $oLayer->setConnectionType(MS_WMS);
> //$oLayer->setConnectionType(8);
> if ($nStatus){
> echo "ok";
> } else { echo "error"; // <=== it always echoes "error"
> $oLayer->set("debug", 5);
> $oLayer->setMetaData("wms_name", $szLayer);
> $oLayer->setMetaData("wms_server_version", "1.1.1");
> $oLayer->setMetaData("wms_srs", $szSRS);
> $oLayer->setMetaData("wms_format", $szFormat);
> Yewondwossen Assefa wrote:
>> Alexandre,
>> What type of layer is that? If your layer type is raster, I think the
>> function would work from what I can see. Maybe try to set
>> $oLayer->set("type", MS_LAYER_RASTER); before the call?
>> Best Regards,
>>> Hi devs,
>>> Any hint about this issue ?
>>> Alexandre
>>>> Hi devs,
>>>> I just installed mapserver 5.4.0-beta1. In mapscript, I'm now not
>>>> unable to use oLayer->set("connectiontype", MS_WMS). I get an error
>>>> saying "use setConnectionType()" instead.
>>>> That's what I did, but it doesn't work with MS_WMS. My collegue
>>>> Julien looked deeper in the code and found out in maplayer.c, in the
>>>> msInitializeVirtualTable, when we use MS_WMS it returns MS_FAILURE.
>>>> So I guess it's no longer possible to set connectiontype to wms in
>>>> mapscript. Is there a new way of doing this ?
>>>> Also, why would a normal mapfile still accept the wms
>>>> CONNECTIONTYPE ? I tried to save my map object as a mapfile and
>>>> only added CONNECTIONTYPE wms and it worked.
>>>> Any hint ?
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
