[mapserver-dev] pdf output development?
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Jan 6 19:45:33 EST 2009
Hi Brent: It's neat to see the possibilities in this area. As an asside I don't think format options
will be useful though. Just too many options. I've wondered if XHTML/CSS could be used, kinda
like query templates. You'd reserve space for the map, legend etc... with css and div's and render
to that space with the appropriate driver. (wonders about tools like webkit, gecko,...) Would be
great to author a map layout in a web editor with text and stuff like that surrounding the map. If
you could do that you'd have a winner. Easy to create with a true map-like presentation.
As for where to go? I wouldn't favor supporting compile-time options, rather run-time defs via
output formats. I think there room for both Cairo and Haru assuming one isn't clearly better than
the other. Any opinions there?
Steve
>>> Brent Fraser <bfraser at geoanalytic.com> 01/06/09 5:31 PM >>>
Hi All,
I've been investigating some enhancements to make the pdf output more suitable for printed map production. So far, aside from some minor bug fixes, I've coded a few new FORMATOPTIONS in my local copy of mappdf.c to allow more user control over the placement and scale of the map on the page:
OUTPUTFORMAT
NAME pdf
MIMETYPE "application/x-pdf"
DRIVER pdf
FORMATOPTION "PAGE_WIDTH=612" # (font points) 8.5 inches wide (72 points per inch)
FORMATOPTION "PAGE_HEIGHT=792" # (font points) 11 inches tall
FORMATOPTION "MAP_MARGIN_LEFT=144" # (font points) 2 inches to the right
FORMATOPTION "MAP_MARGIN_BOTTOM=144" # (font points) 2 inches up from the bottom of the page
FORMATOPTION "SCALEDENOM=50000" # 1:50,000 scale when printed
END
Here's a sample of the output (using the HARU pdf library): http://139.142.13.163/Download/Mapserver/topo2_enh_scale3.pdf
And I've been able to compile Thomas Bonfort's Cairo-based work on Windows XP/VC++ to produce: http://139.142.13.163/Download/Mapserver/topo2_cairo.pdf (note that my modifications for scale and placement have not been applied to this).
It seems like there's been a renewed interest in pdf output lately, so I'm wondering how to proceed with development. Should we allow a choice of PDF renderers (Cairo, PDFlib-lite, Haru) at compile-time/run-time? Re-implement PDFlib/Haru following "plugin" method of the Cairo implementation? Leave them separate for now and see how much PDF-output interest there is in the Mapserver user community?
Opinions welcome...
Thanks!
Brent Fraser
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
