[mapserver-dev] geometry in getfeatureinfo wms request
Alexandre Dube adube at mapgears.com
Fri Jan 9 09:20:16 EST 2009
Instead, you could use a getfeature request that returns geometry by
default. Theses requests can give you response in GML which is far more
structured than getfeatureinfo requests result.
Alexandre
godofredo contreras wrote:
> Hi:
> I have trying to get mapserver returning the geometry in
> getfeatureinfo request, I set DUMP TRUE and the request
> returns attribute data in gml format but not the geometry.
> How can I make mapserver wms return the geometry
> with info_format=application/vnd.ogc.se_xml?
> Thanks in advance
> Godofredo Contreras
> Windows Live™: Keep your life in sync. See how it works.
> <http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_allup_howitworks_012009>
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alexandre Dubé
Mapgears
www.mapgears.com
