Antwort: [mapserver-dev] PDF support wrap up...
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Wed Jan 21 03:12:27 EST 2009
umn-ms at hydrotec.de wrote:
> > ... I'd like to hear more about opportunities to integrate
> MapServer-based
> > PDF output into more complex layouts. Ultimately that's what people
> > want to do. How are folks doing that?
> In some apps we create PDF with Java, XSLT an Apache/FOP.
> * Spatial and non-spatial Data in relational Database
> * Mapserver: Creates PNG-Map from Database
> * Java: Create XML from Database
> * XSLT: Create XSL-FO from XML (links to PNG)
> * Apache-FOP: Create PDF from XML  (embedd PNG)
we are (almost) doing the same. Only, that we use PHP for the XML
generation. We did some experiment using SVG for the map. Anyway, there
might be some enormous improvement once that the Cairo renderer is ready.
> Experience:
> + Can tweak layout
> + Map with true scale
> + Can show additional Database Data in PDF around the map
> + Standardized techniques
> - Apache FOP may run out of memory
Same here. Could the memory problem be solved compiling fop ahead of
time into native code with GCJ? Any experience?
Regards,
Peter
> I can hardly imagine, that a mapserver-only-solution could create
> a customized quality-map.
> Benedikt Rothe
>              Database
>      Java   |         |
>             V         |
>            XML        | Mapserver
>             |XSLT     |
>             V         V
>          XSL-FO     Map As PNG
> Apache-FOP  |         |
>             V         |
>            PDF  <------
> mapserver-dev-bounces at lists.osgeo.org schrieb am 21.01.2009 04:41:04:
> > Brent et al... Lot's of good discussion in the recent PDF thread but
> > I'm not sure there was
> > any decision made. My opinions changed as ideas came forth. I'm in
> > the "keep MapServer
> > as simple as possible" camp. I'd like to hear more about
> > opportunities to integrate MapServer-based
> > want to do. How are
> > folks doing that?
> > Steve
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax  : +39 0473 069902
www  : http://www.r3-gis.com
