[mapserver-dev] rfc49: call for vote
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Jan 23 16:34:14 EST 2009
I think LABELMETHOD is unnecessary at this point and can be removed altogether...
Steve
>>> On 1/23/2009 at 2:58 PM, in message <497A2F64.6050402 at mapgears.com>, Daniel
Morissette <dmorissette at mapgears.com> wrote:
> If LABELMETHOD and labelObj for layer are postponed until after 5.4 then
> I think that should be made clear in the RFC (which is tagged for 5.4),
> or even moved to a separate RFC, otherwise it will be very hard to
> figure out what was done in which release when devs/users look back at
> the RFC in a few years (Yes, I do refer to old RFCs all the time).
> I'm +1 otherwise.
> Daniel
> thomas bonfort wrote:
>> Hi devs,
>> I'd like to get this in for 5.4:
>> http://mapserver.org/development/rfc/ms-rfc-49.html
>> wrapping up the comments from the review period, I think there isn't
>> any issue preventing a vote:
>> * possible values for LABELMETHOD (the default is to use cog) :
>> awaiting implementation, very probably postponed to after 5.4 (unless
>> Steve planned to implement this soon ?)
>> * labelObj for layer: implementation postponed to after 5.4
>> * fractional values also for pattern,gap, offset: a good candidate
>> for 6.0 (when pattern and gap would be moved to the styleObj?)
>> * there was concensus for adding parametered scaling, usefull for
>> thematic mapping (eg size proportional to a feature attribute)
>> - by allowing simple expressions, eg SIZE ( 18 + [poptotal] * ((
>> 43-18)/(5000-30000)) )
>> - or by adding pseudoitems at the layer level:
>> PSEUDOITEM
>> 'mySize' (mrange([itemname], mininput, maxinput, minoutput,
>> maxoutput))
>> 'myText (commify(round([itemname], 2)) + ' ac')
>> END
>> LABELITEM 'myText'
>> CLASS
>> STYLE
>> COLOR 255 0 0
>> SIZE [mySize]
>> END
>> LABEL
>> END
>> END
>> this enhancement will be addressed in a specific rfc.
>> best regards,
>> Thomas
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
