[mapserver-dev] Binding SQL Parameters
Dan Little
danlittle at yahoo.com
Mon Jul 6 16:11:15 EDT 2009
I actually have updated it to use a Mapfile keyword "BINDVALUE" ... In this example I just use BINDVALUE as an array. Given a database like Oracle which lets the user name the parameters I think I'd try to do something like "PARAM=VALUE". Of course, this style may be nearly impossible to duplicate over CGI.
LAYER
NAME 'students'
CONNECTIONTYPE PostGIS
CONNECTION 'dbname=ahsd user=ducky password=ducky1'
DATA "wkb_geometry from students"
FILTER 'elementary_school = $1 or elementary_school = $2'
BINDVALUE '0420'
BINDVALUE '0423'
TYPE POINT
STATUS DEFAULT
CLASS
NAME 'Student'
STYLE
SYMBOL 'ellipse'
SIZE 6
COLOR 0 0 0
END
STYLE
SYMBOL 'ellipse'
SIZE 4
COLOR 255 0 0
END
END
#METADATA
# 'bind_params' '0420|0421'
#END
END
----- Original Message ----
> From: Steve Lime <Steve.Lime at dnr.state.mn.us>
> To: Mapserver Dev <mapserver-dev at lists.osgeo.org>; Dan Little <danlittle at yahoo.com>
> Sent: Monday, July 6, 2009 2:53:49 PM
> Subject: Re: [mapserver-dev] Binding SQL Parameters
> Can you post an example of what your mapfile config looks like now?
> >>> On 7/6/2009 at 2:06 PM, in message
> <381164.32216.qm at web51410.mail.re2.yahoo.com>, Dan Little
> wrote:
> > I've been spending sometime thinking about SQL injection and about filtering
> > complex queries directly through the mapfile.
> > I've been playing with the mappostgis.c file. I am replacing PQexec with a
> > msPostGISExecute function. msPostGISExecute determines whether or not
> > parameters (to be bound) have been passed into the query. If it determines
> > they do exist, then the PQexecParams function is used.
> > Right now, however, I am using a total hack to read the bound parameters...
> > I'm using metadata containing a "|" pipe delimited list. It works for my
> > dataset but there could exist those that actually use the pipe character as a
> > valid value. I would like to add a keyword, or at least have some one
> > suggest a better way to store an array, into the layer. Is there any
> > thoughts on a good keyword name? Thoughts on a fomat? Is there a better way
> > to store an array inside of metadata?
> > Of course, I'm working completely outside of an RFC ... if one were
> > established I would work inside it's parameters I have a short term need but
> > would be willing to revise my maverick work. I have two projects (one in
> > PostGIS, one in Oracle) that could both really use this functionality (so
> > there is some sponsorship for my time to get this done). I also see it as
> > providing a solution set for a number of folks looking to do the dynamic CGI
> > mapping.
> > Thanks,
> > -Duck
> > mapserver-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
