[mapserver-dev] msautotest hanging on Windows due to arecent
change
Tamas Szekeres
szekerest at gmail.com
Sun Jul 12 19:04:41 EDT 2009
Steve,
Thank you for fixing this, that wasn't be so trivial for me to find out the
problem easily ;-)
I've checked this out, and the issue appears to be solved in the recent
version.
Best regards,
Tamas
2009/7/12 Steve Lime <Steve.Lime at dnr.state.mn.us>
> I believe I've fixed this. Graticule layers had screwy functions to manage
> iteminfo. For
> some reason they were mucking with the items/numitems layer attributes and
> the new
> which items code exposed this problem. I imagine this stems from the
> initial implementation
> when, perhaps, there was thought to storing a graticule line's label in a
> an attribute. Instead
> shape->text holds that information. I don't believe graticules need *any*
> attributes and a
> bit of code could be removed from mapgraticule.c. Will create a ticket to
> track that removal.
> Steve
> >>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 07/11/09 8:32 AM >>>
> I'll check... Steve
> >>> Tamas Szekeres <szekerest at gmail.com> 07/10/09 6:09 PM >>>
> Hi All,
> I've found an annoying effect of one of the recent changes in trunk causing
> msautotest (buildbot) to hang in the following command (in
> msautotest/misc):
> shp2img -m grid.map -o result/grid.png
> The process is running in an infinite loop with a significant cpu
> utilization.
> By breaking the execution in a debugger the call stack looks something
> like:
> libmap.dll!_gdCacheGet() + 0x20 bytes C
> libmap.dll!_gdImageArc() + 0x751 bytes C
> libmap.dll!_gdImageStringFTEx() + 0x843 bytes C
> libmap.dll!_gdImageStringFT() + 0x3c bytes C
> > libmap.dll!msDrawTextGD(gdImageStruct * img=0x028e6cc0, pointObj
> labelPnt={...}, char * string=0x02a3a678, labelObj * label=0x02ac17d8,
> fontSetObj * fontset=0x00f0b3e8, double scalefactor=1.0000000000000000)
> Line 2988 + 0x58 bytes C
> libmap.dll!msDrawText(imageObj * image=0x028e6c80, pointObj
> Line 822 + 0x31 bytes C
> libmap.dll!msDrawLabelCache(imageObj * image=0x028e6c80, map_obj *
> map=0x00f0b3a0) Line 2424 + 0x4b bytes C
> libmap.dll!msDrawMap(map_obj * map=0x00f0b3a0, int querymap=0) Line
> 507 + 0xd bytes C
> shp2img.exe!00401ae7()
> [Frames below may be incorrect and/or missing, no symbols loaded for
> shp2img.exe]
> shp2img.exe!00401dba()
> kernel32.dll!7d4e7d42()
> I'd wonder if someone who have better knowledge about the recent changes
> could find out the reason.
> I could see a couple of changes related to msLayerWhichItems which caused
> issues, but I don't see one by one correspondence between those changes and
> this problem.
> Best regards,
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20090713/735bc4fb/attachment.html
