[mapserver-dev] A basic question about mapserver functions
Julien-Samuel Lacroix
jlacroix at mapgears.com
Thu Jul 23 09:36:18 EDT 2009
Like I said, it's two different steps. In the MapScript example, you
create a mapObj and then you draw it. It's the same thing in mapserv.
loadMap():
http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapserv.c#L1237
drawMap():
http://trac.osgeo.org/mapserver/browser/trunk/mapserver/mapserv.c#L1414
Best regards,
Julien
Mauricio Herrera wrote:
> So thanks Julien and Paul. Thanks for help me
> Well I gonna try more specific with my doubt. I answered for each one
> *Julien:*
> Thanks for MapScript examples, but it did not help me. You say “In
> short, msLoadMapInternal loads the mapfile in a Map object and then
> msDrawMap is called”. I looking for this exactly. But I don’t find “the
> intermediate step” between LoadMapInternal and msDrawMap. The Mapscript
> examples show general function like $map =
> ms_newMapObj($map_path."europe.map") and $image=$map->draw();, but
> internally others functions are requiered ..Actually I know:
> 1.-LoadMapInternal()->case LAYER:
> msGrowMapLayers()->initLayer()->LoadLayer()
> 2.-LoadLayer()->case
> DATA:getString()->msValidateParameter->msLookupHashTable() ->msFree()
> *3.- ¿? the intermediate step or function*
> 4- msDrawmap()
> _When or Where DATA (layer->data) provides it’s string to DrawMap()? _
> *Note: *Assuming that all variables of Map Object, Layer Object,Class
> Object (CLASS, SYMBOL, EXTENT, SHAPEPATH, NAME, TYPE,DATA, etc) were
> loaded successfully._ In what function msDrawMap is loaded or is required?_
> *Paul:*
> Thanks it is a good help (drawMap->drawLayer->drawLayerShape). But _I
> don’t understand even When or Where DATA (layer->data) provides it’s
> string to DrawMap() for drawing DATA of a LAYER? And When or Where
> drawMap function is loaded o required?_
> 1.- LoadMapInternal()->case LAYER:
> *3.-¿? the intermediate step or function()*
> *4.- ¿? the intermediate step or function ()*
> 5.- drawMap->drawLayer->drawLayerShape (Paul Ramsey)
> *Note*: Assuming that all variables of Map Object, Layer Object,Class
> Object (CLASS, SYMBOL, EXTENT, SHAPEPATH, NAME, TYPE,DATA,etc) were
> loaded successfully. In what function msDrawMap is loaded or is required
> or automatically it is activaded when LoadMapInternal is ok?
> Am I ok?
> Thanks
> Mauricio
> 2009/7/21 Paul Ramsey <pramsey at cleverelephant.ca
> <mailto:pramsey at cleverelephant.ca>>
> Approximately this:
> p
> On Sun, Jul 19, 2009 at 11:50 PM, Mauricio
> Herrera<georazor at gmail.com <mailto:georazor at gmail.com>> wrote:
> > Hello
> > Really I hope you can help me with next doubt,I appreciate your
> help...
> > Well, I am drawing a function map of mapserver. Because I would
> like to
> > know all internal structure of mapserver. However
> > I have a problem with DATA. I don't understand what function
> links DATA
> > value (layer->data) with next functions:
> > imageObj *msDrawMap(mapObj *map, int querymap)
> > int msShapefileOpen(shapefileObj *shpfile, char *mode, char
> *filename, int
> > log_failures)
> > (LoadLayer) file mapfile.c <----- What is the link function for
> DATA value?
> > --------->(msDrawMap) file mapdraw.c
> DATA value?
> > ---------> (msShapefileOpen) file mapshape.c
> > For example:
> > 1.-loadLayer()-->getString() ---->linkfunction()?------->msDrawMap()
> > filename=layer->data;
> > 2.-loadLayer()-->getString()
> ---->linkfunction()?------->msShapefileOpen()
> > I know that this imageObj *msDrawMap(mapObj *map, int querymap)
> function is
> > used for rendering the map file. Therefore this function
> > must know where the data are located ("/usr/local/geo/street")
> and DATA
> > provides this information with (layer-> data) ... but where does
> it? = S I
> > can not find the function..
> > And I know too that:
> > loadLayer() this function contain a (case DATA:) and this call the
> > functions getString(),msValidateParameter(),msLookupHashTable() and
> > msFree()..But In what moment DATA sends or provides its value to the
> > functions msDrawMap() o msShapefileOpen? where is the link function?
> > I hope you understand me
> > Thanks
> > Mauricio
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Mapgears
http://www.mapgears.com/
