[mapserver-dev] Re: [mapserver-users] msConvertWideStringToUTF8():
General error message. Encoding not supported by libiconv (UTF-16LE)
Daniel Morissette
dmorissette at mapgears.com
Thu Jul 23 11:37:43 EDT 2009
(Taking this back on the list)
Your problem is very likely related to the use of multiple iconv copies
on your system... that LD_PRELOAD doesn't smell good. Do you absolutely
need to do that? Why not use the iconv that comes with glibc?
You wrote that "iconv -l" lists UTF-16LE ... but are you sure that it is
reporting the info for the same version of iconv that your mapserv
binary is using?
The only advice I can provide is make sure you *compile* your MapServer
with the same copy of iconv that you run with, and that this copy of
iconv does include UTF-16LE support.
Daniel
Mr. Bic Phuong wrote:
> Dear Daniel,
> Thanks for your reply,
> 1. To prevent iconv() in glibc 2.5 I have set this line:
> export LD_PRELOAD=/usr/local/lib/preloadable_libiconv.so
> in /root/.bash_profile and
> SetEnv LD_PRELOAD /usr/local/lib/preloadable_libiconv.so
> in /etc/httpd/conf/httpd.conf
> and reboot the server but this didn't solve the problem
> 2. I found that UTF-16LE is listed in the result of the command "iconv -l"
> 3. I manual configure and make the file mapserv for first RHEL 5.3. Then
> I manual configure and make the file mapserv for second RHEL 5.3. I do
> not copy pre-compiled mapserv.
> I hope you can help me to solve this problem Daniel !
> --- On *Thu, 7/23/09, Daniel Morissette /<dmorissette at mapgears.com>/* wrote:
> From: Daniel Morissette <dmorissette at mapgears.com>
> Subject: Re: [mapserver-users] msConvertWideStringToUTF8(): General
> To: mapserver-users at lists.osgeo.org
> Date: Thursday, July 23, 2009, 7:48 PM
> > I hope someone can solve this problem, our project is delayed by
> this error.
> > the GetFeatureInfo function is failed:
> > msConvertWideStringToUTF8(): General error message. Encoding not
> supported
> This error message is telling you that the libiconv library, which
> is used by MapServer for encoding conversions, does not support
> UTF-16LE on that server.
> You need to find out which libiconv your Mapserver was compiled with
> and then make sure that copy of libiconv has support for the
> UTF-16LE encoding. You can list the encodings supported by libiconv
> on a given system using "iconv -l"... make sure UTF-16LE is there.
> > this error accured when I'm setting up a webgis on the second Red Hat
> > Enterprise Linux (RHEL) 5.3, on the first RHEL 5.3, GetFeatureInfo is
> > working perfect.
> Look for a difference between the two servers related to libiconv.
> Daniel
> -- Daniel Morissette
> http://www.mapgears.com/
> </mc/compose?to=mapserver-users at lists.osgeo.org>
Daniel Morissette
