[mapserver-dev] Shapefile goes from 1 sec to 90+ sec just	adding
	a labels!
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Mon Jun 15 15:01:40 EDT 2009
http://trac.osgeo.org/mapserver/ticket/3053
Steve Lime wrote:
> Did this test case materialize anywhere?
> Steve
>>>> On 6/10/2009 at 12:09 PM, in message
> <30fe546d0906101009i38f0e4fuf6e7bc7e2c9e158c at mail.gmail.com>, Paul Ramsey
> <pramsey at cleverelephant.ca> wrote:
>> That's awesome. Want to roll up the data/symbols/fonts into a zip file?
>> P
>> On Wed, Jun 10, 2009 at 10:07 AM, Stephen
>> Woodbridge<woodbri at swoodbridge.com> wrote:
>>> Hi all,
>>> I have run into a very bazaar problem with a shapefile going from 1 second
>>> render times to ~50 second render times just for the geometry, not the label
>>> cache when I add labels to the layer.
>>> I can reproduce this with just one layer and one shapefile.
>>> Has anyone else run into anything like this?
>>> -Steve
>>> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
>>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>>> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>> MAP
>>>  MAXSIZE 4000
>>>  SIZE 800 800
>>>  SHAPEPATH "/u/data/data/Jamaica-900913"
>>>  SYMBOLSET "/u/data/data/Jamaica-900913/symbols/symbols.sym"
>>>  FONTSET "/u/data/data/Jamaica-900913/symbols/fontset.txt"
>>>  IMAGECOLOR "#80B1D3"
>>>  IMAGETYPE agg
>>>  EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
>>>  UNITS METERS
>>>  DEBUG 10
>>>  CONFIG MS_ERRORFILE "stderr"
>>>  OUTPUTFORMAT
>>>    NAME agg
>>>    DRIVER "AGG/PNG"
>>>    EXTENSION "png"
>>>    MIMETYPE "image/png"
>>>    IMAGEMODE RGB
>>>    FORMATOPTION "INTERLACE=false"
>>>    FORMATOPTION "QUANTIZE_FORCE=ON"
>>>    FORMATOPTION "QUANTIZE_DITHER=OFF"
>>>    FORMATOPTION "QUANTIZE_COLORS=256"
>>>  END
>>>  WEB
>>>    METADATA
>>>      wms_srs "epsg:900913"
>>>      labelcache_map_edge_buffer "-10"
>>>      wms_title "jamaica data"
>>>    END
>>>  END
>>>  LAYER
>>>    NAME "World"
>>>    GROUP "cb"
>>>    STATUS DEFAULT
>>>    TYPE POLYGON
>>>    DATA "world/world"
>>>    CLASSITEM "COLOR"
>>>    LABELITEM "NAME"
>>>    CLASS
>>>      EXPRESSION "1"
>>>      STYLE
>>>        COLOR "#99B3FF"
>>>        OUTLINECOLOR "#888888"
>>>      END
>>>      LABEL
>>>        TYPE TRUETYPE FONT "arial" SIZE 7 COLOR "#010101" PARTIALS FALSE
>>> OUTLINEWIDTH 3
>>>        PRIORITY 8
>>>        BUFFER 4 POSITION CC MINDISTANCE 250 MINFEATURESIZE 10
>>>      END
>>>    END
>>>    CLASS
>>>      EXPRESSION "2"
>>>      STYLE
>>>        COLOR "#B3FF99"
>>>      END
>>>      LABEL
>>> OUTLINEWIDTH 3
>>>        PRIORITY 8
>>>      END
>>>    END
>>>    CLASS
>>>      EXPRESSION "3"
>>>      STYLE
>>>        COLOR "#FFE699"
>>>      END
>>>      LABEL
>>> OUTLINEWIDTH 3
>>>        PRIORITY 8
>>>      END
>>>    END
>>>    CLASS
>>>      EXPRESSION "4"
>>>      STYLE
>>>        COLOR "#FFB399"
>>>      END
>>>      LABEL
>>> OUTLINEWIDTH 3
>>>        PRIORITY 8
>>>      END
>>>    END
>>>    CLASS
>>>      EXPRESSION "5"
>>>      STYLE
>>>        COLOR "#99FFB3"
>>>      END
>>>      LABEL
>>> OUTLINEWIDTH 3
>>>        PRIORITY 8
>>>      END
>>>    END
>>>  END
>>> END
>>> Here is the log of just zooming out:
>>> [Wed Jun 10 12:53:35 2009].323025 msDrawMap(): Layer 0 (World), 0.422s
>>> [Wed Jun 10 12:53:35 2009].323329 msDrawLabelCache():
>>> labelcache_map_edge_buffer = -10
>>> [Wed Jun 10 12:53:35 2009].336325 msDrawMap(): Drawing Label Cache, 0.013s
>>> [Wed Jun 10 12:53:35 2009].336355 msDrawMap() total time: 0.438s
>>> [Wed Jun 10 12:53:35 2009].357835 msSaveImage() total time: 0.021s
>>> [Wed Jun 10 12:53:35 2009].358140 mapserv request processing time (loadmap
>>> not incl.): 0.460s
>>> [Wed Jun 10 12:53:35 2009].358160 msFreeMap(): freeing map at 0x63aa00.
>>> [Wed Jun 10 12:53:36 2009].994979 msDrawMap(): Layer 0 (World), 0.786s
>>> [Wed Jun 10 12:53:36 2009].995292 msDrawLabelCache():
>>> [Wed Jun 10 12:53:37 2009].7982 msDrawMap(): Drawing Label Cache, 0.013s
>>> [Wed Jun 10 12:53:37 2009].8014 msDrawMap() total time: 0.801s
>>> [Wed Jun 10 12:53:37 2009].29497 msSaveImage() total time: 0.021s
>>> [Wed Jun 10 12:53:37 2009].29769 mapserv request processing time (loadmap
>>> not incl.): 0.823s
>>> [Wed Jun 10 12:53:37 2009].29789 msFreeMap(): freeing map at 0x63aa00.
>>> [Wed Jun 10 12:53:41 2009].780255 msDrawMap(): Layer 0 (World), 3.827s
>>> [Wed Jun 10 12:53:41 2009].780566 msDrawLabelCache():
>>> [Wed Jun 10 12:53:41 2009].795910 msDrawMap(): Drawing Label Cache, 0.015s
>>> [Wed Jun 10 12:53:41 2009].795941 msDrawMap() total time: 3.845s
>>> [Wed Jun 10 12:53:41 2009].818499 msSaveImage() total time: 0.023s
>>> [Wed Jun 10 12:53:41 2009].818785 mapserv request processing time (loadmap
>>> not incl.): 3.868s
>>> [Wed Jun 10 12:53:41 2009].818805 msFreeMap(): freeing map at 0x63aa10.
>>> [Wed Jun 10 12:54:40 2009].258306 msDrawMap(): Layer 0 (World), 56.436s
>>> [Wed Jun 10 12:54:40 2009].258634 msDrawLabelCache():
>>> [Wed Jun 10 12:54:40 2009].293897 msDrawMap(): Drawing Label Cache, 0.035s
>>> [Wed Jun 10 12:54:40 2009].293931 msDrawMap() total time: 56.474s
>>> [Wed Jun 10 12:54:40 2009].320803 msSaveImage() total time: 0.027s
>>> [Wed Jun 10 12:54:40 2009].321088 mapserv request processing time (loadmap
>>> not incl.): 56.501s
>>> [Wed Jun 10 12:54:40 2009].321110 msFreeMap(): freeing map at 0x63aa00.
>>> [Wed Jun 10 12:56:10 2009].600928 msDrawMap(): Layer 0 (World), 49.215s
>>> [Wed Jun 10 12:56:10 2009].601264 msDrawLabelCache():
>>> [Wed Jun 10 12:56:10 2009].629768 msDrawMap(): Drawing Label Cache, 0.029s
>>> [Wed Jun 10 12:56:10 2009].629802 msDrawMap() total time: 49.246s
>>> [Wed Jun 10 12:56:10 2009].655105 msSaveImage() total time: 0.025s
>>> [Wed Jun 10 12:56:10 2009].655601 mapserv request processing time (loadmap
>>> not incl.): 49.272s
>>> [Wed Jun 10 12:56:10 2009].655623 msFreeMap(): freeing map at 0x63aa10.
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
