[mapserver-dev] --enable-debug and optimization flags
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jun 29 21:19:33 EDT 2009
+1 on changing this. I get tired of having to edit the Makefile to fix
this, when I need to run it in the debugger.
-Steve W
Thomas Bonfort wrote:
> hi devs,
> anyone have an objection if I modify the configure script to change
> -O[123] to -O0 in CFLAGS/CXXFLAGS if --enable-debug was passed to
> ./configure.
> the current behavior is to leave it untouched, resulting (on my system
> at least) in -O2 to be used by default, which is rather incompatible
> with tracing code in a debugger.
> regards,
> thomas
> www.camptocamp.com
> +33 4 79 26 57 97
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
