[mapserver-dev] Query Sandbox: PostGIS
Jim Klassen
Jim.Klassen at ci.stpaul.mn.us
Thu Mar 12 01:20:39 EDT 2009
I made some updates to my previous patch and attached a new patch to #2933.
The new results for the same dataset are:
* trunk takes 6m8s (1m19s in mapserver code)
* prepare takes 1m35s (23.5s in mapserver code)
* single-pass takes 46.5s (26.5s in mapserver code)
* both function=none and function=filter function, although function=none returns one more row than function=filter. function=filter agrees with postgis and shape. I haven't had time to track this down.
Conclusion:
* Single-pass is about 8x faster than trunk.
* In single-pass PostGIS is 2.4x faster than Oracle.
BTW: the bus error in trunk with filter=none appears to be related to a failed malloc. I haven't looked into it enough yet to know for sure what is going on.
>>> "Jim Klassen" <Jim.Klassen at ci.stpaul.mn.us> 03/11/09 6:47 PM >>>
Ok, I feel kind of stupid here in that I should have noticed something was wrong with a file that small. (The DBF of the shape was 300MB). My test dataset is the address points for the City of St. Paul (2D Point with 32 attributes).
Note: single-pass is in ticket #2933, prepare is in ticket #2927, my trunk is at r8765.
It turns out:
* The dataset is 139,000 rows (excluding the ones with null geometry, which mapserver skips)
* The final GML size is 364MB
* The single-pass time to generate that file is 3m17s (1m6s in mapserver the rest waiting for oracle over the network)
* The trunk time to generate the file is 3m21s (1m2s in mapserver) with a bus error at the 100MB mark.
* The trunk+prepare time to generate the file is 1m3s (20s in mapserver) with a bus error at the 100MB mark.
* The PostGIS (from trunk) time to generate the file is 1m21s (17s in mapserver) and finished successfully.
* THe PostGIS (from single-pass) time to generate the file is 19s (14s in mapserver) and finished successfully.
* There is a bug somewhere on using function = none (vs. function = filter which works fine) where the record id seems to be getting mangled causing single-pass to exit early. Also there appears to still be a bug in trunk given the bus errors.
* MapServer appears to use about 25% cpu and 200MB ram on single-pass vs. 33% cpu and 13MB ram in trunk (according to activity monitor). Shark says most of this is spent in OCIStmtFetch2() in single-pass and OCIStmtExecute() in trunk and vs. 38% cpu and 13MB ram for trunk+prepare.
Conclusion:
* Just looking at the rates, single-pass is about 3.58x faster than trunk, and prepare is about 3.2x faster than trunk.
* For PostGIS, I get single-pass is about 4.3x faster than trunk.
* In single-pass PostGIS is 10.9x faster than Oracle. In trunk PostGIS is 8.9x faster then Oracle.
* There is something different with the oracle at the office vs. the sprint because I wasn't seeing bus errors at the sprint.
>>> Jim Klassen 03/11/09 11:39 AM >>>
I added the OracleSpatial patch to track as #2933.
On our 220k point address database the query time went from 6 minutes down to 32 seconds and produced about 360K of GML.
>>> On 3/10/2009 at 10:33 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
I have updated the PostGIS driver in the sandbox to use the new logic.
My timing on outputting 5Mb of GML via WFS query has gone from 12s to
0.5s, a 24x improvement.
Great work Steve!
P.
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
