[mapserver-dev] msautotest-wxs: how to suppress the header information?
Normand Savard nsavard at mapgears.com
Thu Mar 19 13:24:56 EDT 2009
Tamas Szekeres wrote:
> Yeah, I've disabled fastcgi in my compilation and all the problem has gone!
> I wonder how the binaries compiled with fcgi will ever work on windows then.
> As far as I know ms4w uses fcgi enabled in their binaries. Did you mention
> you or Assefa have managed to run the tests successfully by using ms4w? I'd
> be curious to krow what setting could also be applied when enabling fastcgi
> to be compiled in.
Tamas,
This is a good question. Assefa and I effectively ran the tests
successfully on Windows. I guess we can ask to Jeff how he is building
MapServer within ms4w with fcgi enabled.
Norm
