[mapserver-dev] mapserver 5.4 beta performance test
Guillaume Sueur
no-reply at neogeo-online.net
Tue Mar 31 10:49:53 EDT 2009
Another weird point :
If I ask for the whole dataset, 5.4 is slower than 5.2 (11 and 9 secs)
but with a filter on an indexed field, I get 0.607s with 5.4 and 2.3s
with 5.2.
If I use the shapefile of the data I get :
whole dataset :
5.4 : 1s
5.2 : 1s
with a filter on :
5.4 : 0.76s
5.2 : 0.76s
So, as far as I can tell, shapefile still goes much faster than PostGIS
layers, with various differences between 5.2 and 5.4
5.2 and 5.4 are equal when dealing with shapefiles.
Does this sound ok for you devs ?
Regards
Guillaume
Guillaume Sueur a écrit :
> Hi,
> I'd like to share some strange results I've got back when testing
> mapserver 5.4 beta on a huge streets postgis layer.
> here are the tests :
> 5.4 beta DEBUG ON -----------------------------------------------
> time /usr/local/src/mapserver-5.4.0-beta3/shp2img -m test.map
> [Tue Mar 31 15:49:15 2009].935351 msDrawMap(): Layer 0 (streets), 1.617s
> [Tue Mar 31 15:49:15 2009].935551 msDrawMap(): Drawing Label Cache, 0.000s
> [Tue Mar 31 15:49:15 2009].935603 msDrawMap() total time: 1.619s
> [Tue Mar 31 15:49:16 2009].24176 msSaveImage() total time: 0.089s
> [Tue Mar 31 15:49:16 2009].24347 msFreeMap(): freeing map at 0x818f8e0.
> real 0m1.719s
> user 0m0.284s
> sys 0m0.028s
> 5.4 BETA DEBUG OFF ---------------------------------------------
> time /usr/local/src/mapserver-5.4.0-beta3/shp2img -m test.map -o test.png
> real 0m1.994s
> user 0m0.408s
> sys 0m0.020s
> as you can see it goes faster with debug ON (tested several times)
> if I try it back with mapserver 5.2 I get :
> 5.2 DEBUG ON -----------------------------------------------
> time /usr/local/src/mapserver-5.2.0/shp2img -m test.map -map_debug 5 -o
> [Tue Mar 31 15:52:01 2009].891334 msDrawMap(): Layer 0 (streets), 1.434s
> [Tue Mar 31 15:52:01 2009].891549 msDrawMap(): Drawing Label Cache, 0.000s
> [Tue Mar 31 15:52:01 2009].891603 msDrawMap() total time: 1.437s
> [Tue Mar 31 15:52:02 2009].43083 msSaveImage() total time: 0.151s
> [Tue Mar 31 15:52:02 2009].43240 msFreeMap(): freeing map at 0x81878e0.
> real 0m1.599s
> user 0m0.268s
> sys 0m0.016s
> 5.2 DEBUG OFF -----------------------------------------------
> time /usr/local/src/mapserver-5.2.0/shp2img -m test.map -o test.png
> real 0m1.481s
> user 0m0.296s
> sys 0m0.008s
> So the 5.4beta seems definitely slower than 5.2, and goes even slower
> when DEBUG is off.
> Is there a special setting activated by default on beta releases which
> could explain that ?
> Best regards
> Guillaume
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
