[mapserver-dev] Mapserver 5.6.0-beta5 perl bug
Andy Colson
andy at squeakycode.net
Tue Nov 17 10:02:50 EST 2009
> Andy Colson wrote:
>> Hi all,
>> I'm not sure, but might have a little problem. I have this code,
>> which I'm almost positive used to work:
>> $x = $map->OWSDispatch( $owreq );
>> if ($x)
>> print STDERR "ERROR: OWSDispatch: $x\n";
>> my $errObj = new mapscript::errorObj();
>> while ($errObj) {
>> $errObj->{code}:$errObj->{message}:$errObj->{routine} \n";
>> $errObj = $errObj->next();
>> I had a problem with my mapfile and should have gotten errors, but my
>> error log just contained:
>> ERROR: OWSDispatch: 1
>> ERROR: 0::
>> ERROR: 0::
>> ERROR: 0::
>> There is an error, but there is nothing in mapscript::errorObj. Did
>> usage change or anything?
>> -Andy
Daniel Morissette wrote:
> Nothing should have changed, the function should still return
> MS_SUCCESS(0)/MS_FAILURE(1) if it finds a valid OWS request, or
> MS_DONE(2) if it the request is not recognized as a valid OWS request.
> It's always possible that something changed or got broken in one of the
> handlers, but we'd need a way to reproduce. I'd suggest you file a
> ticket with a testcase to reproduce the issue (sample request and
> whatever mapfile/data is required to reproduce).
> Daniel
Shoot, I made a simple perl cgi app and it worked correctly. My real
app is using mod_perl however, so I'll work up a little test case for
that.
-Andy
