[mapserver-dev] symbol lazy-loading
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Nov 21 10:43:13 EST 2009
Thomas,
I think for historical reasons maybe, but also for management reason, a
lot of people have large repositories of image symbols, and a single
symbolset file. I build mapfiles for a lot of people, and use a common
repository, but in most cases only a few, less than 1%, are used in any
one mapfile.
Part of the reason for this is that if you ship a mapfile to a client,
you also need to send the symbolset, fontset, etc. and it is just easier
and less error prone to tar up a standard directory of these support
files. It is a pain when you ship something only to find that some file
or another is missing and the product is broken when deployed remotely.
I think a lot of people would benefit from this.
On the other hand, as the symbology definitions are getting better and
better in mapserver, I also find that I rely less and less on the older
image symbols, but that just may be me.
-Steve W
thomas bonfort wrote:
> Pavel,
> On Wed, Nov 18, 2009 at 13:24, Pavel Iacovlev <iacovlev.pavel at gmail.com
> <mailto:iacovlev.pavel at gmail.com>> wrote:
> Good day all,
> As I understood on render request mapserver loads all symbols into
> memory thats is fine if you have under 64 symbols (default limit).
> recent versions of mapserver aren't limited to 64 symbols anymore.
> I
> have a topographical map to render that maybe will have around 200+
> symbols and like 5-10 will be used per request. Maybe implementing
> lazy-loading (only then needed) for symbols will improve the
> performance ? and remove the cap at all.
> lazy loading of symbols would definitely make sense for image symbols,
> although only for people with a single symbolset for multiple instances,
> as otherwise the case is rarer to have defined a symbol but never use it.
> the other symbol types wouldn't see much benefit from lazy loading imho,
> as this is only a parser operation that has to be done anyways.
> Another question is if I have
> 100 image symbols all 100 images are loaded into memory on render
> request ?
> yes, all the image files are loaded.
> regards,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
